| diyAudio Sponsor | ||
Hi all,
My question is in this schematic for the power tube cathode resistor this 2001 edition is using 1.5K, while for SRPP schematic its using 880ohm, and the older model is 2X1.5k. Is the 1.5K for the 2001 edition is meant for 45 tube or can I use it for 2A3 tubes? 45/2A3 means this circuit can be used for either 45 or 2A3 tube without any modification on the circuit? Need some clarification I almost done the amp then notice the other value of cathode resistor on the other JE circuit I intend to use 2A3 tube only so the 1.5K for cathode resistor is okay. Thank you very much Mac_G |
#2 |
Can you please post the schematics?
#3 |
Hi Here is the schematics, its also tap on 5K impedance, while other 2A3 is using 2.5k for the output transformer. and here's the link http://members.myactv.net/~je2a3/simple45.htm
thank you
#4 |
Hi!
If You use 2A3 with recom. plate current 60 ma, the bias will be -90 v with res. 1,5 kohm. This bias is very big /recom. is 45-55 v for best mode/. Cathode res. must be 800-1000 ohm. If You use 2A3 with plate current 35-40 ma, 1,5 kohm is suitable, but sound will be bad. I think /I use in my 2A3 820 ohm Mills/ res. must be less 1 kohm. 1,5 kohm is for tube 45 with plate current 35-40 ma. |
#5 |
Thank you very I'm a newbie based on the circuit cathode voltage is 55V where it come from and how to compute it (cathode voltage).
based on 2A3 data sheet plate dissipation = 15W max Some circuit use 880ohm but difficult to find I have a 820ohms but the Plate dissipation will be 55V/820 = 67ma 275V x 0.067A = 18.425W which is over the 2A3 max is t okay, if okay then I will use it or is there need to do some modification on the circuit I intend to use 2A3 tub only. thank you |
#6 |
Hi all, tried to search then now know how to compute the cathode voltage based on the 60ma current recommend for 2A3 and the bias voltage recommendation of 45V - 55V using the ohms law to calculate the cathode resistor. thank you
| EC52--Plate choke--300B/45/2a3/50/EL34 SE | tube-lover | Tubes / Valves | 11 | 4th October 2011 06:39 PM |
| New SET: JE labs simple 45 or tubelab SE? | cwujek | Tubes / Valves | 14 | 27th November 2007 04:15 AM |
| Tube designs: 45 driving 45/2a3/300b? | Veniogenesis | Tubes / Valves | 4 | 23rd April 2007 06:59 PM |
| WTB: OPTs for 2A3 or 45 SE; 240 v power tranny for 2A3 or 45 | rick57 | Swap Meet | 0 | 8th November 2006 01:07 AM |
| JE LAB's 2001 2A3 & Preamp??? | wwflyball | Tubes / Valves | 18 | 4th March 2006 12:49 AM |
| Page generated in 0.08066 seconds (76.90% PHP - 23.10% MySQL) with 10 queries |
