diyAudio Sponsor
Old 27th February 2010, 07:55 AM   #1
gorko1 is offline gorko1  Slovenia
Default Aikido help!
Hello,
Im bulding my Aikido line stage. PCB is ALLinONE LSA/HSPA. I will use 6CG7/6H30 for line stage. B+ will be 300V. I have troubles with R10 resistor.
If I look in table are there R10=82,9k for 6CG7/(B+300V/7,3mA) and R10=76,5k for 6H30/(B+300V/15mA). Now what to chose? For inpute tube or outpute tube? And there is also formula R10=R9( (mu-2)/(mu+2) ). But once again witch mu to use? For input or output tube or maybe both???
Please guys be so nice and help me.
BR,
Goran
Old 27th February 2010, 10:25 AM   #2
SY's Avatar
Your schematic doesn't have the parts designators. But assuming these are the resistors in the series noise nulling circuit, the mu is that of the White cathode follower (second tube).
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 28th February 2010, 07:47 AM   #3
/subscribed
I'm building the same setup for a friend.
Did you go for a separate heater transformer? That combo needs loads of heater current!
Old 28th February 2010, 07:51 AM   #4
Originally Posted by TheShaman View Post
/subscribed
Yes I know. I will go for separate. How much current do you think is optimal for heater transformer?
BR,
Goran
Old 28th February 2010, 08:35 PM   #5
BR,
Goran
I'm in the process of building an Aikido (point-point wiring).
The heater current rating needs to easily exceed the draw of 4 tubes that have heater currents equal to the highest of the bunch. Typically, that's 0,6A per tube at 6.3v. So 4*0,6A=2,4A. You would need a 3 Amp rated transformer or higher.
Gary
My Aikido!! piero7 Tubes / Valves 9 31st August 2009 10:56 AM
Aikido pre Julien_M Tubes / Valves 8 31st July 2009 01:38 AM
Aikido Resistor Help Bengali Tubes / Valves 2 11th May 2009 11:11 PM
Aikido HiFiNutNut Swap Meet 1 24th January 2007 04:26 AM
How did you do your Aikido? Original Burnedfingers Tubes / Valves 18 7th December 2005 03:26 AM
Page generated in 0.08697 seconds (74.78% PHP - 25.22% MySQL) with 11 queries
