diyAudio Sponsor
Old 25th February 2010, 08:23 AM   #1
regal is offline regal  United States
Default Really subjective question
I'm embarking on building a new tube headphone amp. I guess I've always used tubes that are known for audio. But for this amp I want to build a SE zero feedback spud type with an OPT. The 6EW7 and the 6c45pi would perform really well on paper but they aren't really classic audio tubes. My other option would be to sacrifice some power/gain and use a classic WE417A/5842.
What due you think is more important specs or classic tubes? The reason I ask is because my 6SN7 based head amp sounds 100x better with 1940's RCA's vs new tubes and my 6DJ8 headamp sounds 100x better when I use old Amperex vs newer tubes. So I am leary of the 6EW7 and 6c45pi where there are practically no tube rolling options and audiophile qualities are practically unknown.
Old 25th February 2010, 10:09 AM   #2
SY's Avatar
Neither. Performance in a proposed circuit is #1 for me. "Classic" is fun, no argument, but I want my boxes of gain to PERFORM.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 25th February 2010, 12:52 PM   #3
Yvesm is offline Yvesm  France
Yvesm's Avatar
I follow Stuart ... adding that neither 6C45pi nor 417 was originally designed for audio use
And that 99% of the 6SN7 production spent their live in vertically sweeping spots in B&W TV sets.
Yves.
Old 25th February 2010, 01:09 PM   #4
Why is the 6EW7 rarely used, seems the perfect tube to drive anything from headphones to DHTs on paper ?
Old 25th February 2010, 01:45 PM   #5
Yvesm's Avatar
Mmmh ...
The gain of the small triode is too low to fully drive the large one from an usual audio source.
May be a reason for its desaffection
Yves.
Old 25th February 2010, 02:18 PM   #6
Glowbug is offline Glowbug  United States
Glowbug's Avatar
One thing that's cool about DIY is the ability to use a tube that really works well in a design, that might have had nothing to do with audio originally
Besides, the "non-audiophile" tubes are cheaper, and there are boxes upon boxes of them sitting around for years to come.
Jim J.
Old 25th February 2010, 02:47 PM   #7
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Seen this 6EW7 design? I have a few 6EW7's and I'll use em one day for sure.
Attached is GLUCA's design, which he uses as a headphone amp.
Old 26th February 2010, 10:08 AM   #8
Cool design.
This is what I am thinking of building. I want low output impedance and high power. This puts the tube at its lowest Rp. I am on the fence with going parafeed, but I lose a lot of power. The big expensive commercial tube headphone amps all use gobs of power.
Old 26th February 2010, 10:40 AM   #9
Should work like a charm!
Old 26th February 2010, 10:50 AM   #10
SY's Avatar
Regal, in a conventional circuit, one would AC couple between driver and output stage. This circuit eliminates that, but then AC couples the output stage. So you've removed a small (~100nF) cap from the signal path, and to do that, you then stick a big (50u) cap into the signal path. Which cap is likely to be more ideal?
Subjective evaluation consort_ee_um Everything Else 0 6th December 2007 10:21 AM
THE best subjective sound ? medogrizli Solid State 11 30th May 2007 11:56 AM
Subjective lunacy mikeks Solid State 24 18th September 2006 02:36 PM
Page generated in 0.11359 seconds (80.32% PHP - 19.68% MySQL) with 11 queries
