diyAudio Sponsor
Old 24th February 2010, 02:55 PM   #1
dehtak is offline dehtak  Czech Republic
Default Output transformer from rowe ammi mm4
Hallo ,
i have 2 output transformers from ROWE AMI MM4
I do not know how to get sekundar output
this color ist:
Black
brown-white
white
yellow
green
green-white
green-yellow
Old 26th February 2010, 11:53 AM   #2
Default I found schematics
I do not understand the connect. This is not stereo. This speaker is connect serial from right and left output transformer. This si MONO
Rowe AMI jukebox amp richfoub Tubes / Valves 10 3rd January 2011 02:32 AM
wooohooo! Three Rowe AMI amps for $200NZD! aardvarkash10 Tubes / Valves 5 23rd February 2010 07:57 AM
Rowe Ami 125W Amp Board Inputs coit Solid State 0 11th February 2010 05:18 AM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Page generated in 0.05792 seconds (72.02% PHP - 27.98% MySQL) with 11 queries
