can I use OFC speaker cables - Page 2 - diyAudio
Old 10th June 2003, 01:20 AM   #11
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
can you guys recommend a PTFE wire i can use as hookup wire? those available from Farnell or RS Components if possible.
i'll be starting my CX-345 amp ASAP, and i'd like to go all out on wiring
Old 10th June 2003, 12:03 PM   #12
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Originally posted by arnoldc
Can you guys recommend a PTFE wire I can use as hookup wire? Those available from Farnell or RS Components if possible.
I'll be starting my CX-345 amp ASAP, and I'd like to go all out on wiring
It's not what you use, it's the way that you use it
If you can put a large order together (>2kg), you can go to a bullion dealer and buy 99.99% pure silver in the form of wire at a surprisingly reasonable price. You then buy PTFE sleeving and put one inside the other...
Alternatively, you could use PTFE insulated wirewrap wire, but you will need to buy the proper tool to strip it. The possible advantage of wirewrap wire is that it is so thin that it is easy to do true star earthing and take every connection back to the star point individually. True star earthing is well worthwhile, even if it means twenty wires or more going to your star earth point.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th June 2003, 01:37 PM   #13
Circlotron's Avatar
Originally posted by Morse
If you want something better, teflon insulation is a joy to work with (it doesn't melt as easily with the cavalier application of a soldering iron the way some other insulation types can).
A joy to work with?!?! Have you you ever tried using a wire stripper on it?
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 10th June 2003, 03:15 PM   #14
dhaen is offline dhaen  Europe
dhaen's Avatar
Yes. If you use a "dinosaur" shape stripper, it just can't grip the PTFE insulation and makes a mess of it.
But if you use a stripper that encompasses the insulation with blades, and you pull the wire manually (such as stripper designed for Kynar), it's a beautiful strip
Old 10th June 2003, 04:48 PM   #15
EC8010's Avatar
A "dinosaur" shape stripper? The mind boggles. Do you mean "diamond"?. You're absolutely right, though, it needs to be the proper (outrageously expensive) stripper with a blade all round.
PS Circlotron, I love your sign-off. Just envious I didn't think of it first...
Old 10th June 2003, 05:13 PM   #16
dhaen's Avatar
Looks like a T-Rex to me....
Old 10th June 2003, 05:15 PM   #17
EC8010's Avatar
LOL. I see what you mean!
Old 10th June 2003, 09:03 PM   #18
diyAudio Senior Member
fdegrove's Avatar
If you want high Q cabling use silver wire...
For stripping PTFE insulated wire use a sharp penknife, just be careful not to cut the wire proper.
Frank
F1 or F2 with MIT speaker cables? roscoeiii Pass Labs 1 13th July 2009 12:47 AM
Your Speaker Cables... jleaman Multi-Way 41 17th May 2006 02:29 AM
how much did you pay for speaker cables peteS Multi-Way 43 12th March 2006 01:22 PM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
Copyright 1999-2017 diyAudio
