diyAudio Sponsor
Old 23rd February 2010, 10:42 PM   #1
Default Problem with short Test
Hello everyone.
I have one accurate 151 tube tester, and im not sure if the "short test" works properly
When i test a valve ( even a new valve), a very smooth light shines on the indicator on most of the switch positions, but the light shines fully only when the selector is in the position marked as " disregard indicator lightning" in the manual . In some positions no light.
Is my tester broken? All my tubes must be discarded? When i do a test quality after, all have a "GOOD".
Thanks for helping and sorry for my english
Kind Regards
Old 24th February 2010, 03:09 AM   #2
HollowState's Avatar
This tester is an old timer. I don't think all your tubes are bad. I do think your tester may need some maintenance. If the short light glows dimly on a "known to be good" tube, you are probably seeing leakage. This can be caused by faulty calibration due to age from resistors or adjustments that have changed. It can also be caused by contaminates like moisture (humidity) and dirt getting inside on the switches and sockets. Most testers are set to a one megohm threshold for leakage indications. Consult your manual for calibration procedures. Perhaps remove the tester from the case and examine the inside for signs of contamination and clean as necessary.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 24th February 2010, 01:12 PM   #3
Tom Bavis's Avatar
Many emission testers have a capacitor in the leakage test circuit that will cause false "short" readings if it's leaky. And if that capacitor is original, there's a very good chance it's leaky.
Old 24th February 2010, 02:19 PM   #4
thanks for the quick response, I remain your advice.
Kind Regards
Why doesn't it short? Or am I missing something? wwenze Construction Tips 7 23rd January 2010 03:26 AM
Square waveform test/simulate problem mclarenpingu Solid State 3 2nd February 2008 04:08 PM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
How short can a TL be..? Ian J Multi-Way 10 31st March 2003 01:03 AM
Page generated in 0.07894 seconds (70.90% PHP - 29.10% MySQL) with 10 queries
