| diyAudio Sponsor | ||
Building a 12AU7 cathode follower line buffer after a stock 2 volt cd player. Want to run a simple C-L-C using (2) Solen 47uF PPE caps. Told to buy a Hammond 5H choke. My power supply is 125v-125v, 12.6v 300mA heaters. There are so many different values of 5H chokes http://www.tubesandmore.com/scripts/...RC&PAGE=SUBCAT Want to end up with 95-100 vdc B+ What choke should I buy? Any comments on 12AU7 would be appreciated. I purchased the Decware EM0705 125v-125v, 12.6v 300mA supply. If this supply can run a couple of 5687"s or a single 6922 or 6N1P I would be very interested in trying other routes besides the ECC82. ZKIT5 power supply kit |
#2 |
Use double PI LCLC filter with choke input. That means there is no capacitor between the rectifier and the first choke.
Johnny |
#3 |
The 6N1P is 6.3v 600mA heated, so your supply won't work with that tube.
| Choke input power supply, capacitor ratings | 00940 | Tubes / Valves | 14 | 7th July 2009 05:52 PM |
| 12 vdc to 18 vdc isolated P-P | jamesrnz | Power Supplies | 89 | 4th February 2009 03:36 PM |
| using 40 VDC supply? | Wind | Tubes / Valves | 5 | 14th January 2006 08:21 PM |
| 48 VDC Power Supply construction ?s | PaulHilgeman | Parts | 2 | 15th January 2003 12:14 PM |
| Using fuses on VDC Power Supply Rail? | Lucas_G | Pass Labs | 4 | 22nd December 2002 09:37 PM |
| Page generated in 0.06582 seconds (71.16% PHP - 28.84% MySQL) with 10 queries |
