diyAudio Sponsor
Old 22nd February 2010, 07:36 AM   #1
Default What is this tube?
I have a couple of 1943 Amperex JAN-CEP-120 tubes, NOS in boxes.
It looks like a smaller version of a 211(vt-4c) or 845, the only reference I can find about them is a pair for sale on a chinese website last year.
Does anyone know what they are and/or have any specs?
The picture attatched shows an amperex 211, the cep-120 in the middle and an 845 on the right for scale.
If suitable, they would make a cute SE amp, but replacements could be scarce.
Dave.
all sorts of stuff
Old 22nd February 2010, 08:09 AM   #2
mobyd is offline mobyd  New Zealand
mobyd's Avatar
Looks a lot like a ZB120 to me
http://tubedata.tigahost.com/tubedat...11/z/ZB120.pdf
M
Old 22nd February 2010, 08:12 AM   #3
Hey neighbour!, it certainly does and no doubt you know who it came from
all sorts of stuff
Old 22nd February 2010, 08:27 AM   #4
mobyd's Avatar
Lemme guess :
RNZAF Weedons -> Ferrymead museum -> Lyttelton tube chap -> You
Anyway, got plenty of spares if you do build something
Cheers
M
Old 22nd February 2010, 08:35 AM   #5
Arnulf is offline Arnulf  Europe
I hope you don't mind me using your topic
Can anyone identify tube in photo ? It is a noval (9-pin) tube, about the same height as EL84, there appear to be few pins unconnected which would indicate a double (FM detector ?) diode. The print has been completely wiped off and the etching doesn't look like anything familiar either. I believe it came from an old radio, although I can't be 100% sure of that. I've never seen a double diode arrangement with anodes perpendicular to one another, sharing same heating element in the center
(photo is 335 KB in size, not dialup friendly)
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 22nd February 2010, 08:41 AM   #6
mobyd's Avatar
If it had 7 pins I'd say 6X4 - 9 pins it probably is an RFT brand 6CA4 aka EZ81
M
Old 22nd February 2010, 02:26 PM   #7
Ez81!
Old 22nd February 2010, 07:54 PM   #8
Wow guys, it never occured to me that those small anodes could take that much current so my assumption was some oddball detector diode, but based on your replies I went searching for photos and came across this one which looks precisely like what I've got here.
This is the kind of EZ81 I was used to seeing, it looks completely different.
Old 23rd February 2010, 11:08 PM   #9
Originally Posted by mobyd View Post
Lemme guess :
M
Close enough
Any thoughts so far in their suitability, or has anyone ever heard them working in an Audio amp?
all sorts of stuff
Old 24th February 2010, 10:15 AM   #10
Steerpike's Avatar
Could be an EZ80, almost the same as the EZ81, but lower crrent.
Steerpike's Toybox
Simple Tube Mono Block Tube Amp Schematic jleaman Tubes / Valves 16 24th November 2009 08:42 PM
can't find valve art tube - and glowey tube pic wicked1 Tubes / Valves 23 10th February 2009 12:54 AM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Page generated in 0.09250 seconds (79.62% PHP - 20.38% MySQL) with 11 queries
