| diyAudio Sponsor | ||
I just picked this up at my local surplus shop and I'm having a hell of a time trying to track down any info on it.
Surplus Mystery Amp on Flickr - Photo Sharing! The labeled tube sockets are from when somebody recently pulled the tubes out of it. I believe the 6BQ5 and 12AX7, but that octal is not a 6SN7, its a rectifier tube for sure. There are some numbers on the transformers and the unit itself all of which have lead me nowhere on the Google. Chassis: 8466942 062903 Power Xfmr: 95 1743 524022 Outputs: 95-1790-AJ 172 602 95-1780-B 172 6022 There are 3 pots on the front, as well as a 2 or 3 position lever switch. There is a sticker labeled "Speaker Terminals" that lists "TV Audio In" as well as a red, black, and white quick connect. Looks like it had a 120V cord thats been snipped as well as an aux 120V plug. Thanks for any help. |
#2 |
Zenith chassis 4F20. Schematic is in Sams folder 558-15. With some Zeniths, two different output transformers give a "sum" output for a mono extension speaker.
#3 |
Fantastic, thanks. Of course its the one number on the thing I didn't search for.
I found a nice looking example currently on eBay: VINTAGE ZENITH 6BQ5/EL84 TUBE AMP STEROPHONIC 12AX7 - eBay (item 400103615640 end time Mar-16-10 20:26:24 PDT) A little steep if you ask me. Know I don't know if I want to bring this guy back to life or just rob it for the power transformer and chassis for my Blue Velvet preamp build. |
#4 |
It would seem apparent that it's not a stereo amp as advertised due to only one out put tube.
#5 |
Are you sure about only 1 output tube? I count 2 6BQ5's.
#6 | |
I think Tom Bavis has provided an important clue. Those O/P trafos appear asymmetrical. FWIW, my inclination is to rebuild the bugger into a nice little SE amp, as that power trafo energized both the amp and a tuner, which makes it way oversized for a preamp. Consider a variation on the RH84 (schematic uploaded) theme. Install a pair of $37.01 Edcor GXPP15-6-8K O/P trafos. The heft associated with a 15 W. rating should give you extension into the 1st audio octave, at the 5 W. a pentode mode EL84 yields. An additional tweak is to regulate each EL84's g2 B+ with an individual LR8 IC. It's likely the OEM rectifier was a 5Y3. You can increase the B+ rail voltage, without overstressing the 5 VAC winding, by installing a 5V4.
Eli D. |
#7 |
Agreed that the OPTs appear asymmetric. Still, I would be interested in using them if possible, looking at the faceplate of the amp in the eBay auction, it does show a 'stereo' mode as well as mono and ext stereo. So I would think there must be a way to use them as relatively symmetric.
I'll need to head to the library and dig up the Sams schematic. |
#8 | |
Zenith was both clever and CHEAP. The 2 sections operated out of phase. They functioned to produce a mono center bass channel and 2X stereo HF channels. Unless you want to construct a speaker system for that sort of setup, replace the O/P "iron". A pair of 95+ dB. efficient speakers will mate nicely with 5 WPC. In a small space, a little less efficient will work.
Eli D. |
#9 |
That sounds like just the kind of odd ball setup that intrigues me.
I might have to send these OPTs over to my DC Double Darling and free up the 125ESE's on it for this SE EL84 duty. Assuming I can get the primaries to work out OK. |
#10 | |
A look at Hammond's connection diagram suggests using the green and black wires, as the speaker connection.
Eli D. |
| Motorola 3 channel Tube Amp from Console | john65b | Tubes / Valves | 9 | 11th July 2010 05:12 PM |
| Magnavox console amp, SE EL84, $50 | pjanda1 | Swap Meet | 5 | 27th January 2008 09:02 PM |
| FS: Vacuum Tubes (12au7, 12ax7, 6dj8, EL84) | mrdon | Swap Meet | 4 | 28th October 2006 08:13 PM |
| old console radio as guitar amp | ghola | Tubes / Valves | 8 | 3rd March 2006 02:50 AM |
| help building 12ax7/el84 amp | buliwyf | Tubes / Valves | 1 | 25th October 2005 02:57 PM |
| Page generated in 0.10728 seconds (81.18% PHP - 18.82% MySQL) with 11 queries |
