300B SE amp: One more one - Page 2 - diyAudio
Old 22nd February 2010, 10:55 AM   #11
Yvesm is offline Yvesm  France
Yvesm's Avatar
Originally Posted by Rod Coleman View Post
Salut Yves,
Tell us about the output transformer - was it the quality you used at ETF2009? With success!
The design of that transformer would be interesting to see.
Short before lunch . . .
Do we meet ? Refresh my brain please !
I like to claim that I've built this amp ONLY to check the OPT !
Indeed, the ETF09 shotout was just the pretext to do something using those legendary triodes
Yves.
Old 22nd February 2010, 11:14 AM   #12
regal is offline regal  United States
What is F .315 in your PS schematic? Do you have a part # for it?
Also you may consider a larger ultrapath cap C1 ?
Old 22nd February 2010, 11:30 AM   #13
Tubes4e4's Avatar
Fuse, 315mA.
Tom
If in doubt, just measure.
Old 22nd February 2010, 12:07 PM   #14
Yvesm's Avatar
As said before C1 is not Utrapath and can't be because the cathode of the 300B is (almost) grounded.
C1 is just here to reduce PSU impedance at hi end.
Probably higher value won't hurt if this does not disturb the serie regulator.
Guys, all your remarks urge me to bring to amp back on the bench for further tests
I'll consider that while taking a nap
Yves.
Old 22nd February 2010, 04:17 PM   #15
Yvesm's Avatar
Since you've asked:
http://www.dissident-audio.com/SE_300B/KISS/DA143.pdf
Yves.
Old 22nd February 2010, 06:12 PM   #16
работник
Rod Coleman's Avatar
Yves,
I like Heretical design approaches, so I am a fan of Dissident Audio for designs like PC900 phono, DIY curve tracer, and of course DIY OPT.
I did not show for ETF2009, but found some Shootout results:
European Triode Festival - ETF2009 Shootout
Vraiment, il est remarquable de battre Partridge OPT à un concours - félicitations!!
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 02:13 PM
Home made SE 300B amp JosM Tubes / Valves 12 6th August 2008 06:33 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 05:18 PM
My 300b SE amp purer Tubes / Valves 2 28th December 2002 05:25 AM
Copyright ©1999-2017 diyAudio
