OPUS 5.0 A Modern Mullard - Page 11 - diyAudio
Old 23rd March 2010, 03:38 AM   #101
Lost another FET after powering down and moving amp to test on main speakers. Must be exceeding Vgs limits either during power down or up. I would think a zener would be appropriate here. Lost only one side of the pair. Nice thing about this is the tube shuts down when it fails.
Any thoughts on this?
Living Life Doing the Waltz in 4/4 meter.
Old 23rd March 2010, 03:51 AM   #102
Originally Posted by SGregory View Post
It is playing music now. Tomorrow is a day for measuring and tweeking.
Way too early for impressions other than it has power.... Lots of it. I can clip the output tubes before I clip the driver.
It is very clear and dynamic. Drums are incredible campared to my SET. Curious to see the distortion spectrum... May have to look at that tonight.
B+ is still running about 490V. Plates are not glowing after an hour at 62mA bias.
Best of all no smoke! Just a couple of FETS that went silently in the night before.
I should mention that the above scope pictures were aat the onset of clipping of the driver stage.
A decent design should clip the "finals", before the small signal circuitry clips.
No lack of "stones", as it should be.
Tweak away! Get the residual hum level down. Adjust the phase compensation cap. value, to get a good looking 2 KHz. square wave.
Eli D.
Old 23rd March 2010, 01:52 PM   #103
Tubelab_com's Avatar
Yes, a zener (or two in series opposing) should be wired from gate to source. I blasted a few IRF830's before I switched to fets with the zeners built in like the Toshiba 2SK3563. I didn't realize that the IR (Vishay) parts still don't have them.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 23rd March 2010, 03:39 PM   #104
I have some 2sk3564's which I may install tonight. The have 15pF reverse capacitance which is higher than the irfbc20's 8pF. Having the zeners internal to the device should have the lowest capacitance vs. using external zeners.
The 2sk3563's are better than the 64's in regards to reverse transfer capacitance but will have to order them. I don't have any zeners in my box greater than a couple of volts unfortunatley.
Old 24th March 2010, 12:43 PM   #105
Need some help here. I spent most of the night last night tracking down a very high frequency unstable oscillation.
The problem occurred after I installed the new spec FETS (ended up going back to the original spec during trouble shooting.) Without the KT88's in, I could set bias anywhere I wanted no issue, however once I put the KT88's in I would get up to about 10mA of bias current and then "click", the current would shoot up to 180mA. I used the word "click" because you could hear the tubes click when it started to run away. With the osc scope I could see the drive voltage start to oscillate. Once the oscillation started it couldn't be stopped unless the amp was powered down.
I was able to get the current low enough by biasing direct to the c- rail to measure. At this point I have not hooked up GNFB.
I found that the whole input circuit was oscillating. I dropped input impedance to 50k and problem stopped. I also put 510R carbon comps on all of the tube grids right at the pin. Amp is quite now and plays wonderfully. However not all is quite right.
I find that I have a 1mV RMS very high frequency oscillation (possibly noise) >>50mHz on the input to the kt88 prior to the grid stopper. It does appear on the gate side of the fets but at a much lower level. I was wondering if a ceramic cap on the FET rails would be of value here? Being that my bias circuitry is a pretty high impedance, I am wondering if I am picking up noise from the environment (i.e phones, wireless router etc.) by putting these on the rails to shunt this noise to ground.
I can't see the oscillation/noise on the B+ supply. But the signal is getting back to the input tubes some how, so I plan on increasing the decoupling from the output stage to the LTP and driver on the power supply. I have more than enough drive so losing a few volts of swing will not hurt the amp at all.
Any other things I should persue to clean it up further?
FYI Ripple on B+ is <<1mV
Old 24th March 2010, 11:40 PM   #106
Default Version 2 Measurements
Amp is doing pretty well now with No Feedback. No stability issues what so ever. I increased the decoupling between output and driver stage which really quieted down the noise I was seeing.
Attached are the latest measurements. Running 485V B+ for output stage and 470V for driver stage.
The first is a picture of the THD vs. freq for 50,55, and 60mA Bias. The second is the spectrum at 40W output. and finally a picture of the square wave. top trace is amp and the bottom trace is of input. My signal source isn't great and my 2nd channel on th scope isn't right, I can't calibrate it correctly. The leading edge of the input is really identical to output trace. I won't complain about the scope as it was given to me a while back.
Absolutley NO Hum visable or perceptable.
Added latest schematics as well
Now to add NFB
Last edited by SGregory; 24th March 2010 at 11:41 PM. Reason: added latest schematics
Old 25th March 2010, 02:00 AM   #107
boywonder's Avatar
Excellent progress!!
Would larger R value grid stoppers take care of the oscillations shown on the square wave?
I had ringing on the leading edge of the 10Khz sq wave in my no gfb EL34 triode amp only when changing input amplitude; they would immediately decay at steady state.
Adding grid stoppers took care of the problem completely, although the leading edge is a bit rounded.
Old 25th March 2010, 02:50 AM   #108
The ringing/oscillations comes from the source. The output is almost identical to the input. The only difference is that the top edge has a slope to it in the output. I need to get a better signal generator!!!! In my latest design update, I did up the value of the grid stoppers to 510 carbon. Maybe I should order some 1k carbon and see if things improve further?
I am in the process of trying employ the feedback to no avail. I need to look at things a little closer tomorrow. I put a 100k pot in instead of the 10k specified. What is weird is that when I drop the resistance to increase the feedback I get more gain, distortion also increases. I checked the input signal and the output signal and both are in phase so technically I should get a reduction in gain. Thinking that my scope may be screwed, I flipped polarity on the OPT and it oscillates wildly at power up. (even at 100k resistance).
Little stumped right now. So instead of messing it up tonight, I stopped, biased in my good Genelex tubes and hooked it into my main system. Incredible!!! The bass vibrates my windows!!!! I am using a SS Rotel on the other channel and there is a clear advantage to the new tube amp. The speaker dissappears. It can almost live without NFB if it didn't have so much gain.
Old 25th March 2010, 03:12 AM   #109
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Keep it around 6-9dB NFB when you will successfully close the loop. How much is your measured open loop gain? I use 1k on my KT88s, one or two oscillated if I did not up the value more, but stopped when I used 1k Koa Speer carbon. Its in triode mode. Here is its 10kHz square with feedback loop closed, after Cdom over Rf. 31dB gain, 8.5dB NFB.
P.S. Maybe you need to up the grid stoppers around your input valve too. Maybe you got to adjust your probe too?
Old 25th March 2010, 03:16 AM   #110
Find some little ferrite beads that will just slip over the leads of the stopper resistor. Put one or two on the leads to the gate of the the fet, and on the grid stopper resistors. A2 and screen driven amps often must run with low value or no stopper resistors, ferite beads are often the only way to tame the oscillations.
Modern 3 way crossover design LucasAdamson Multi-Way 2 1st February 2010 09:48 PM
modern allrange speaker Arnold_R Full Range 5 20th October 2009 03:04 PM
Modern cd's - over compression VanHal Music 113 12th March 2008 10:02 PM
Need help- modern replacement for old trannie DeonC Parts 4 7th March 2008 11:52 AM
JLH with modern output transistors diegot Solid State 8 13th August 2006 09:05 PM
Copyright 1999-2017 diyAudio
