| diyAudio Sponsor | ||
I built a 2A3/45 amp and one tube seems to have 1/2 the output of the other. I'm not sure if it's the tube or the amp.
I checked the Anode voltage and it's 310 on both tubes but when I looked at the Cathode voltage, One is 38v, (close to the 45v that I should see) but the other is only 22v? I checked the value of the 750 ohm cathode resisters and they are both 749. If I move the tube from one channel to the other the voltages follow the tube. Any idea's Is it the tube or something I I may be doing wrong. -- Thanks |
#2 |
If the problem moves with the tube, it is almost for sure a weak tube. Do you have any other output tubes to try or can you test your tubes on a tube tester? I am assuming both output tubes are the same type.
- John Atwood |
#3 |
There were a matched pair and I don't have another pair or tube to try. My Heathkit tc-1 tube tester does not show a 2A3 on the config so I can't test the tubes, I have a 45 pair coming but don't have them yet. I am thinking it may be a week tube but thought I should check to make sure I didn't miss something.
#4 |
38v/750 = 51 ma - good emission /this is normal mode/.
22v/750 = 29 ma - bad emission. Maybe Your ampl. will work good after 2-3 days work? And emission second tube will increase.... Or You can try put in cathode 500 ohm for a few hours to increase emission? Last edited by azazello; 20th February 2010 at 07:31 AM. |
#5 |
I could swear that my TC-1 has configurations for 2A3's. Alas it is down stairs and I am warm and comfy in bed. If you don't mind giving me until morning I can check it out for you then. I just cannot remember off hand.
#6 |
JPeitzman:
If you have the config for the 2A3 that would be great My Heathkit TC-1 scroll paper will not scroll that low, I need to fix it but it's so old I don't want to break the paper. If you have the config for the 2A3 that would be great. Azazello: Thanks. I will run it today again for a while just to see if it improves. I think I will also get another tube also. |
#7 |
Heathkit TC-1 2A3 Configuration:
Type - 3 Filament - 2.5 Plate - 28 Top - BC Bottom - D Yeah my scroll paper is probably in about the same condition, something I too have been meaning to fix. Hopefully this helps!
#8 |
Thanks JPeitzman
I tested the tubes and the one was bad. Thanks everyone ! |
| parallel SE 2A3 | sunrise | Tubes / Valves | 20 | 29th August 2008 07:41 PM |
| pentode in triode mode SE vs a DHT SE like 2a3/300b | jarthel | Tubes / Valves | 49 | 30th April 2007 12:25 AM |
| WTB: OPTs for 2A3 or 45 SE; 240 v power tranny for 2A3 or 45 | rick57 | Swap Meet | 0 | 8th November 2006 01:07 AM |
| New driver for SE 2A3 | camotecue | Tubes / Valves | 11 | 23rd August 2006 04:53 AM |
| 2A3 SE Amp | sunseeker | Tubes / Valves | 4 | 28th March 2005 01:24 PM |
| Page generated in 0.09259 seconds (75.07% PHP - 24.93% MySQL) with 10 queries |
