| diyAudio Sponsor | ||
Hi All.
I have a GTA SE-85 that is a real piece of work. I was still working at a dealer when I purchased it for personal use some 11 yrs ago, and if anyone knows about these (they don't work........period ) i have listened to it maybe 10 hrs in 10 years.The problem is, according to a tube amp guy I have looking at it, that the screen's are at 700 volts and EL-034's should be at a max of 425 volts. If anyone has had any luck with finding a way to correct these to work properly I would love to know. It is like this. AudiogoN ForSale: Golden Tube SE-85 Dave. |
#2 |
frugal-phile(tm)
Dave,
Do you have a schematic? My 1st thot would be to regulate the screen supply (for pentode) or put a level shifter on the screens (psudeo triode) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Do you have the schematic? We're flying blind without it.
Eli D. |
#5 |
Hi guys.
The gentleman who is looking at it for has it. I will get a copy tomorrow if he can fax it to me. Dave. PS. Thanks for the fast response. |
#6 |
Hi guys.
Here are the schematic's of the SE-85. Let me know what you think. Dave. |
#7 | |
Can you convert those files to gif or jpg? No MS Word here and Word Pad can't handle the imbeded graphics.
Eli D. |
#8 |
#9 |
Hi.
Sure can. Quaility may suffer. I can email them to you if you wish. PM me with your email. Dave. Last edited by service_guy; 20th February 2010 at 01:06 AM. Reason: PDF's Added |
#10 |
Thanks to Ty. I got a look. The resistor in series with the EL34 screen grid limits current. Still, I think Planet10 gave good advice. Have the tech install a Maida style regulator in each channel. Not only is the g2 voltage held within published limits, regulating g2 B+ is a proven method for improving the linearity of full pentode mode O/P tubes. Full pentode mode is what I see in the drawings.
Eli D. |
| replace attenuator on Golden Tube SEP-1SE | wintermute222 | Parts | 2 | 3rd October 2011 07:37 PM |
| schematic diagram golden tube se40 for repair! help | attilio.mazzone | Tubes / Valves | 8 | 2nd February 2008 07:08 PM |
| Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? | nelsondog | Everything Else | 1 | 11th November 2007 05:00 PM |
| Golden Tube Audio 300B se | dshortt9 | Tubes / Valves | 2 | 4th November 2005 01:30 PM |
| Golden Dragon Tube | TunaFish | Tubes / Valves | 6 | 11th January 2004 10:00 PM |
| Page generated in 0.10818 seconds (75.87% PHP - 24.13% MySQL) with 11 queries |
