diyAudio Sponsor
Old 17th February 2010, 05:42 PM   #1
alexg is offline alexg  Philippines
alexg's Avatar
Default Weird EL84 PP behavior
I breadboarded an EL84 PP amp today.
6n1p driver, EL84 triode strapped. B+ of 280VDC.
Am using a Lundahl 1660S as interstage/phase splitter, plate voltage on the 6n1p is 190VDC with two red LEDs on the cathode.
On the output stage, I first biased it using two paralleled 270R 2-watt resistor bypassed with 100uf cap (the cathode resistor is common to the two output tubes). I was getting 21VDC on the cathode, 155ma for both tubes, which is quite odd, I was expecting arund 10 to 11VDC. So I thought my loadline computation was wrong. Just to verify, I then used a 330R 9 watt resistor connected to both cathode of the PP pair and suprisingly, I was getting 58VDC on the cathode! The 9 watt resistor was getting hot! I thought I have a quad of bad EL84, replaced the tubes with another brand, same thing.
It is 2:40am here, am beat, I will check my work again tomorrow.
This is weird!
Any ideas? I just checked my cathode resistor and it reads 332 ohms on my Fluke digital meter.
Old 17th February 2010, 06:01 PM   #2
Svein_B is offline Svein_B  Norway
Where are the grids of the EL84 connected? Are they at DC 0 level?
If the grids are at GND level, and you get that cathode voltage, you must have some serious oscillation.
I guess those EL84 were glowing quite red hot with the high current.
Svein
Old 17th February 2010, 06:30 PM   #3
richwalters's Avatar
EL84 is a high gm tube 11mA/v. Given even a half chance it will oscillate. Got an oscilloscope around ?
richy
Old 17th February 2010, 09:51 PM   #4
alexg's Avatar
The grids are connected to the secondaries of my Lundahl 1660S.
The amp sounds great, btw.
I also noticed this that the paralleled 270R resitors (2 watt) that I first use as common cathode resistor of the EL84 were burned.
Unfortunately I don't have an oscilloscope.
Old 17th February 2010, 10:10 PM   #5
jueic is offline jueic  Taiwan
Hi, Alex
How about disconnecting EL84's grids from the transformers and ground them
with 1k resistors.. just to make sure the output tubes function ok by themself.
Jueic
Old 17th February 2010, 10:38 PM   #6
alexg's Avatar
Stupid me, I did not wire the Lundahl 1660S to ground!
Now bias voltage is spot on.
Thanks guys.
Old 17th February 2010, 11:53 PM   #7
So, grid leak did not bias the secondary below the cathode voltage???
Where did a positive charge come from? I know that can happen if
heat from the plate cooks a grid until it emits. But how does that
runaway process begin here? I would have expected from my limited
experiments with floating grid, this node tends to bias itself a volt or
more negative. How in this circumstance does the plate ever get hot
enough to cook the grid into emitting more electrons than it captures?
Old 18th February 2010, 05:24 AM   #8
alexg's Avatar
Actually the amp before i grounded the interstage is quite stable, not red plates and it sounds great, no distortion. But the cathode voltage is too high for the bias that I set and the tubes are conducting too much current. I don't know where it was getting the bias.
The interstage is gapped, the secondary should not have any positive charge (or is there?). I think that the secondary should just have A/C on it.
It is quite confusing for me, as a newbie, that when I increase cathode resistance, the voltage across the resistor increases which does not follow the plate characteristic of a triode strapped el84.
Old 18th February 2010, 05:26 AM   #9
alexg's Avatar
Originally Posted by jueic View Post
Hi, Alex
Jueic
I did this and the EL84 behaved as expected.
Somehow not grounding the CT of the secondary and the ground of the primary of the LL1660S interstage caused my problems.
EL84 PP output transformer for 6L6 PP class A engels Tubes / Valves 8 30th May 2007 09:45 AM
El84 Pp Tobruk Tubes / Valves 1 1st May 2007 12:05 PM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
El84 Pp Mr. Triatic Tubes / Valves 11 7th August 2005 04:23 PM
Page generated in 0.10263 seconds (79.44% PHP - 20.56% MySQL) with 10 queries
