diyAudio Sponsor
Old 16th February 2010, 07:17 PM   #1
tim614 is offline tim614  United States
tim614's Avatar
Default "groundbus" is this right?
Trying to figure out the groungbus thing, please point me on the right direction.
Old 16th February 2010, 08:18 PM   #2
HollowState's Avatar
Hi Tim, Nice drawing. You have the right idea...almost. I would make the following change. From the three large main filter capacitors, instead of looping the buss up and around to the input tube area, connect it from the middle filter straight across to the center area near the output tubes. The idea is to keep the buss line short and compact. Use a nice heavy piece of copper wire (#12). Make the chassis connection from the center of the buss to either where it is now or perhaps centered near the tubes. You only need standard hookup wire for this chassis connection btw.
One more observation, why not interchange the PS input capacitor to the upper position. This would slightly shorten the b+ supply line to the tubes as drawn now.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 16th February 2010, 08:23 PM   #3
tim614's Avatar
thanks HollowState!
i would but there's no room
Old 16th February 2010, 08:30 PM   #4
chrish is offline chrish  Australia
chrish's Avatar
What you need to do is think about the return currents flowing through the ground bus. You want to keep the high return currents from the power supply and power tubes separate from the small signal currents of your input tube. The best hint on the order to hook up the components to the bus is the order they are drawn on the schematic. In other words, grid leak for input tube, cathode resistor input tube, cathode bypassfor same, input grid leak power tube, cathode bias resistor poewer tube and it's bypass cap, then power supply filter capacitors... Keep the big power currents away from your small signal return currents.
Cheers
Old 17th February 2010, 06:35 AM   #5
kavermei's Avatar
Send a message via MSN to kavermei
Yes, best practice is to run the ground bus from the main capacitors to the output tubes first, only then to the input tubes, and finally to the input sockets. Basically, the way you wired the B+. This way, you keep the big currents away from the input stage.
If you choose to connect signal ground to chassis (=earth), it can be done either at the input (just use standard RCA sockets) or at the main filter capacitor (then you should use insulated RCA sockets).
Happy building!!!
Never send a human to do a machine's job. --Agent Smith
Old 17th February 2010, 01:16 PM   #6
jrenkin is offline jrenkin  United States
what drawing program did you use? It looks useful.
Old 17th February 2010, 02:02 PM   #7
tim614's Avatar
i just use paint.
Old 17th February 2010, 02:12 PM   #8
kavermei's Avatar
Originally Posted by tim614 View Post
i just use paint.
It contains the word "pain"
Old 17th February 2010, 04:23 PM   #9
Nuts, I was hoping it was something fancier. I like stuff like that, but I have enough to learn about tubes without adding how to use a paint program too
Nice job with paint though.
31 Band Equalizer "the t.eq" "TQ-60" schematic wanted tiefbassuebertr Solid State 2 29th March 2010 03:45 PM
Wanted to Buy: Pairs of 5-1/2";6-1/2";8";10" Seas Aluminum Woofers dtm1962 Swap Meet 0 15th January 2010 04:38 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Randy Slone's "Fig 11.4" (Self's "Blameless"?): PCB layout tcpip Solid State 126 15th February 2007 04:50 PM
4"x8" Port = two 4"x4" Ports for MLTL??? More Complex??? OTMOPO3OK Full Range 2 17th January 2005 03:58 PM
Page generated in 0.10442 seconds (80.58% PHP - 19.42% MySQL) with 11 queries
