diyAudio Sponsor
Old 16th February 2010, 01:44 AM   #1
Default 8ohm output transformer with a 4ohm load
I know if you run too high of a impedance load on a tube amp the plates could fry just like if you had no speaker attached. But what happens when you pop a 4ohm speaker on a 8ohm tap? Is it perfectly safe as long as you dont go above the normal wattage of the amp? I dont know what happens when the tubes see 2.5k instead of 5k.
Aka if its a 10 watt amp at 8ohms, dont go for 20watts at 4ohm , keep the volume at half...
Old 16th February 2010, 06:19 AM   #2
In such a case you will get much higher distortion, since distortion increases as the tube's load impedance decreases.
Also, it seems to me that you'll get less output power, since the operating point of the tube will not be suitable for the new load impedance.
Old 16th February 2010, 07:06 AM   #3
Ian444 is offline Ian444  Australia
What happens if you put 4 ohm resistors in series with the 4 ohm speakers, besides halving the output power to the speakers, all else should be OK as far as the amp is concerned? Yes? No? Halving the power is only -3dB. Sure its not the "right thing" to do but if you're stuck...
Ian.
Old 16th February 2010, 10:33 AM   #4
sacpul is offline sacpul  Malta
It is better to use 2 inseries 4 ohms speakers instead of 4ohms resistor. It will be better from my experience. Btw the 4ohms resistor needs to by high wattage coz it will blow
Old 16th February 2010, 07:09 PM   #5
Ian.
Halving the damping factor too.....
4ohm and 8ohm LR4 xo LukeDuke Multi-Way 1 17th April 2008 05:09 PM
4ohm speakers for 8ohm application? SikSS Full Range 4 15th December 2007 04:09 PM
8ohm or 4ohm? adrrad Chip Amps 5 21st October 2007 04:29 PM
4ohm Sub driver to 8ohm Sub amp? WBFAir Multi-Way 10 31st March 2007 01:29 AM
4ohm Car Speaker to 8ohm Use? jdgonko Car Audio 1 20th April 2006 02:40 AM
Page generated in 0.07767 seconds (76.69% PHP - 23.31% MySQL) with 10 queries
