| diyAudio Sponsor | ||
This is my first post and this will be my first build. I search the forum and www for some time and am not finding the answer to this; so here it goes.....
On the tubelab simple se design it uses a single 12AT7 in the preamp to handle both channels. I realize that this is a "dual triode"- but can you really get true stereo separation running both channels through the same tube? Would there be any advantage to separating the pre-amp into two individual circuits (sounds like I am trying to build simple se monoblocs now!?!) I am hoping that I am just naive about this. Your first amp has such a fast learning curve but I am loving it! |
#2 | |
I used to use separate supplies for left and right channels, because I could hear a small amount of crosstalk if I had input on one channel only (BTW, I could hear no crosstalk after separating the supplies, meaning I could hear none from the dual triode input tube). I found that I could not hear any difference in actual stereo playback, so I no longer worry about it. In fact, you'll find some folks who think that significantly less separation sounds better. I think, for typical designs, it's more important to consider isolation between amplifier stages, than it is between channels. The small amount of crosstalk you'd get between typical dual triodes is, IMO, completely harmless to good stereo reproduction. Sheldon Last edited by Sheldon; 14th February 2010 at 04:44 PM. |
#3 |
Thanks, all I needed to hear.
#4 | |
Cross talk from stray wiring capacitance will be much worse. Cross talk within the 12AT7 will be the least of your concerns. |
#5 |
Thanks for your reply. Answered my question and made me realize the answer was right there amongst the specs. Learning, learning. I had a hard time putting my head around the fact that the plate and grid share such close proximity without any cross-talk.
| Tubelab Simple SE questions | Skorpio | Tubes / Valves | 18 | 3rd May 2010 02:43 PM |
| Electrolyticless Tubelab Simple SE | nic6paul | Tubelab | 21 | 10th April 2010 08:00 PM |
| Tubelab Simple SE Schematic | Salsero | Tubes / Valves | 2 | 12th December 2009 12:37 AM |
| Tubelab Simple SE v.2 | nic6paul | Tubes / Valves | 3 | 1st November 2009 12:59 PM |
| Second Tubelab Simple SE board done | budmaestro | Tubes / Valves | 0 | 24th July 2008 12:18 AM |
| Page generated in 0.08632 seconds (75.50% PHP - 24.50% MySQL) with 10 queries |
