| diyAudio Sponsor | ||
Hi all.
This is the internals of a 15-20 year old Cary amp. Can anyone tell me what the purpose is of the yellow Kimber cap acrooss the filter cap (reduce ripple, I assume?)? Should this be changed considering it's age and does it contribute in any way to the sound of the amp? If I change the cap out, any recommendations as to what I should purchase? Also, should I replace the two 220uf 100v electros in the pic? I was thinking about going with some Elna's here but won't consider it if it might be a waste of time and money. Thanks. PS- I was in the middle of changing the coupling caps to Mundorf Silver/Gold's when I took the picture which is why they are missing. I decided against oil caps because of the reliability issues I've been hearing about especially when subjected to a lot of heat and this includes the Mundorf Silver/Oil. The Silver/Golds, btw, sound phenomenal with only about 30-35 hours burn in. Definately worth $21.74 each! Last edited by Monjul; 13th February 2010 at 07:25 PM. |
#2 |
#3 |
#4 |
Why would you want to replace it - has it developed huge ESR or went short or something ?
#5 |
Don't know as I don't have the means to measure the caps. I'm basing the idea on the age of the amp but I'm also thinking about getting better sonics if replacing these caps with more modern versions would accomplish this. I guess that's my main question at this point.
#6 | |
The blue ones? Those are right in the signal path and have a huge sonic impact. Plus, being electrolytics, they are likely to dry out. They are a good choice for replacement -- maybe a big solen film cap?
http://www.ecpaudio.com |
#7 | |
#8 |
Parts Connexion has 220u/400V Solen caps.
#9 |
#10 |
работник
If the electrolytics are really 15-20 years old, they will be most probably degrading the sound. I find the sound goes bad long before the ESR or capacitance develops any measurable change.
for screw terminal reservoir/filter caps, the KEMET/BHC ALS series are well worth the look: FEBG - Electrolytic Capacitors |
| Polar electro with bypass cap to replace nonpolar as coupling cap? | at77 | Parts | 0 | 12th January 2010 02:05 AM |
| Low-ESR cap -vs- Normal cap with sunbberized. | nina | Chip Amps | 11 | 11th September 2005 07:20 PM |
| Can a X2 cap be used in place of a snubber cap? | w00t | Parts | 6 | 26th February 2004 02:50 PM |
| Auricap, Hovland or NO Cap?[Search for the Best Cap] | Elso Kwak | Solid State | 8 | 16th May 2003 05:48 AM |
| .22uf cap in place of .25uf coupling cap, OK? | bbaker6212 | Tubes / Valves | 5 | 15th July 2002 09:08 PM |
| Page generated in 0.11130 seconds (82.92% PHP - 17.08% MySQL) with 11 queries |
