diyAudio Sponsor
Old 13th February 2010, 09:58 AM   #1
Default help please with kt-88 ultralinear o/p transformer
Hi everyone this is my first posting on youre forums and would just like to say a bit of a tube novice. I have a pp ultralinear output transformer in a 60w kt-88 amp but it is wired for 200 ohm output i know it has the windings for 16 ohm 8 ohm etc but do not have the knowledge on how to rewire it i have a picture and have marked the windings which i checked with a multimeter each winding appears to be approx 0.8 ohms i am just unsure on what to link for output feedback etc can any one help please many thanks
Old 13th February 2010, 05:31 PM   #2
taj is offline taj
taj's Avatar
My guess:
C = common (or ground)
CT= 4, 8 16 ohm "center taps"
200z = as marked.
This is not authoritative, just a guess.
..Todd
Old 13th February 2010, 08:41 PM   #3
Thanks for youre help Todd ill give it a try tommorow (look for the blue flash on the horizon about midday) ha ha cheers gavin
KT-88 pair zargon1 Swap Meet 2 11th October 2008 12:40 PM
Another KT-88 cryo Tubes / Valves 23 1st October 2008 03:06 PM
KT-88 from a book diesel_tech Tubes / Valves 20 25th February 2008 01:07 AM
Need PP KT-88 amp design and KT-88 for triode use? Norris Wilson Tubes / Valves 7 23rd February 2005 12:12 PM
Page generated in 0.05863 seconds (69.53% PHP - 30.47% MySQL) with 11 queries
