diyAudio Sponsor
Old 12th February 2010, 04:47 PM   #1
Default 5v to 2.5v for 2a3 filament
What would be the best(simple) way if possible to drop 5vac 3amp to 2.5v at 2.5a for heaters for a single 2a3 tube??? Sorry for the dumb ? Hope someone has a simple answer. Thanks in advance.
Old 12th February 2010, 05:15 PM   #2
Arnulf is offline Arnulf  Europe
An additional transformer or altered existing winding.
All other solutions will waste power or potentially cause noise.
Old 12th February 2010, 11:09 PM   #3
pauldune's Avatar
Arnulf is right.
However, you could rectify it, and put a 2.5A CCS behind it. Causes a lot of heat in the ccs though...
Old 12th February 2010, 11:45 PM   #4
7n7is's Avatar
Ohms law -> V = IR
R = V/I
2.5/2.5 = 1 ohm
The heater has a resistance of 1 ohm with 2.5 V across it and 2.5 amps of current going through it. A dropping resistor will have the same current going through it and must have a voltage across it of 2.5 volts (2.5 + 2.5 = 5).
Use a 1 ohm dropping resistor.
Also see Voltage divider - Wikipedia, the free encyclopedia
Old 13th February 2010, 02:58 AM   #5
jrenkin is offline jrenkin  United States
Could you drop with an RC filter and eliminate some of the noise the other guys are commenting on?
Old 13th February 2010, 08:47 AM   #6
If "R" part is doing the dropping it will heat up (inclusion of a capacitor doesn't affect that), as mentioned above. An alternative would be capacitive dropper, 2600 uF in series with the filament for 1R @ 60 Hz (mains frequency in the US). The problem is finding 2600 uF non-polarized capacitor, but one could substitute two larger capacitors in series (inverse) instead.
This might actually be the best solution as - just like transformer - it doesn't waste power in the form of heat, and on top of everything it also doesn't cost nearly as much or weigh as much as a suitable transformer.
Old 13th February 2010, 09:01 AM   #7
hkoetz is offline hkoetz  Netherlands
hkoetz's Avatar
2 2A3's is series?
Lateral is best!
Old 13th February 2010, 09:18 AM   #8
pauldune's Avatar
Originally Posted by hkoetz View Post
2 2A3's is series?
remember: filament=cathode!
+5v regulator mekanoplastik Digital Source 33 14th June 2010 05:33 AM
WTB: Tentlabs DHT filament supply 2.5V recstar24 Swap Meet 0 25th September 2009 11:12 PM
Why 5V filament mashaffer Tubes / Valves 12 15th August 2007 07:56 AM
1.5v To 5v... li_gangyi Everything Else 11 10th November 2003 05:41 AM
Can you make 0-5V DC out of 2.5-0-2.5V AC Ralph Tubes / Valves 17 23rd September 2003 03:20 PM
Page generated in 0.10369 seconds (77.23% PHP - 22.77% MySQL) with 10 queries
