| diyAudio Sponsor | ||
I have the luxury of owning 4 se opt's, all the same type, 2.5K primary and 8Ohm secondary.
I was wondering, is it's possible to combine 2 opt's to act as one push-pull opt? 5K pri, and 4 or 16Ohm secondairy? Regards, Rob |
#2 |
Rob,
A workable solution along the lines you want is to build 4X "identical" SE channels. Separate the channels into 2 pairs. The I/Ps of each pair are connected in parallel. The O/P trafo secondaries of each pair are wired in series. Use 4 Ohm speakers. The method described above is not PP, instead it's "strapping". Also, the method requires that the O/P trafo secondaries float. If the secondaries are grounded, as is the case for GNFB, an alternate method ("bridging") is necessary. "Bridging" drives the I/Ps of each section with 180o out of phase signals. The grounds of the 2 sections are tied together and the speaker is connected to both "hot" terminals. A 4 Ohm speaker is appropriate here too.
Eli D. |
| possiblity of Denon 2560GL act as an decoder | liuyuer | Digital Source | 0 | 19th December 2009 02:06 PM |
| Can single PCM56P act as stereo? | terranigma | Digital Source | 1 | 27th February 2007 09:29 PM |
| and the prize for stupid act of the week goes to..... | wintermute | Multi-Way | 34 | 22nd November 2005 11:33 AM |
| Halving OPT's pri.imp. by connecting 8ohm load to 16ohm tap - Good/Bad? | argo | Tubes / Valves | 16 | 23rd May 2005 04:33 PM |
| balancing act | JRKO | Solid State | 5 | 1st August 2004 04:59 PM |
| Page generated in 0.07026 seconds (73.69% PHP - 26.31% MySQL) with 10 queries |
