What tubes for a tube amp? - Page 11 - diyAudio
Old 2nd March 2010, 01:16 PM   #101
Send a message via MSN to bacon665
When you rectify 120volts you get the Peak output voltage which is some 147 volts.
Essentially (if your in america) you can take two 1:1 transformers, run the primaries in parallel, on the secondaries tie the negative of the first to the positive of the second. where the secondaries connect is your ground. the other two leads go to the bridge rectifier and the +/- of the bridge is your +/- 147. The rest of the circuit for the powersupply is the float/filtering/smoothing/protection/regulation
Old 2nd March 2010, 01:38 PM   #102
markusA is online now markusA  Sweden
markusA's Avatar
Let's remember there are a lot of us guys out here with 240VAC.
Old 2nd March 2010, 01:57 PM   #103
Originally Posted by bacon665 View Post
What are these values and is it safe to go to the closest size instead of exact values?
So far, it's not a case of "close, but no cigar"; instead, we miss by a wide margin. For the Class-A2 output stage, we need to target inductors that can, at an absolute minimum, reliably pass a continuous 500mA, so we need something rated for at least 1A in order to conservatively operate the components. If we're going to design power-supplies that can sustain the rated 60-watt (RMS) output specification, the steady-state current requirement becomes something closer to 2.4A. Of course, we don't want too large of a voltage-drop across the inductors or the power-output levels will start to modulate against the power-supplies; low DCR values will be important.
So we need moderately high-inductance value inductors with a low DCR and a high heat-dissipation rating. A possible candidate would be something like the Jantzen copper-foil air-core inductors (DCR: 0.85-ohms, power handling: 350 watts RMS for 16 gauge, 500 watts RMS for 14 gauge and 650 watts RMS for 12 gauge). The problem is that the largest inductance value in that product line is 4.7mH, which when flanked by a pair of ~3000uF capacitor banks (C-L-C filter configuration) only gives us a -3dB corner-frequency of 42Hz. To best serve the M-60 signal path, we really need to have a corner-frequency that is well below the audio frequency band. The more traditional iron-core choke designs can certainly provide higher inductance values, but their current/heat-dissipation capacity is limited and they can easily reach core saturation (degrading performance). Before we start stacking-up multiple off-the-shelf inductors, I wanted to see if some custom inductors might offer us an alternative that saves space/weight in the chassis at a decent price-point.
Mullard EL34
Old 2nd March 2010, 01:58 PM   #104
Originally Posted by markusG View Post
I suppose it'll be linear psu's?
Keeping with the kiss principle would imho be a good idea since we're talking about a diy project.
Yeah, Class-A vacuum-tube circuits and linear power-supplies are natural partners...
Mullard EL34
Old 2nd March 2010, 02:00 PM   #105
Not to worry; that's why I had targeted power-transformers that have primaries which can be wired for either 120VAC or 240VAC...
Mullard EL34
Old 2nd March 2010, 08:19 PM   #106
atmasphere's Avatar
Its nice to have the windings on three different transformers. The windings talk to each other so if one is loaded it will affect the others. That's why we use a separate B+ transformer for the output, a separate filament transformer and a separate driver B+/B- transformer.
We don't use a choke in the output section, just a 1 ohm 5-watt resistor. If the output section is really balanced, the sawtooth isn't a problem. We do use a choke in the B- of the driver, solely for V4 cathodes. The B- for V3 is fed by a 1K 1 watt resistor that comes directly off of the rectifiers, in parallel with the choke. We don't have any chokes in the B+; the 3K device that feeds V4's plate comes off the rectifiers, and is in parallel with another 1K unit for the plates of V2. We bypass the plates of V4 w/200uf, same for its cathodes. 100uf bypasses the plates and cathodes of the voltage amplifier.
The output section supplies are typically about 6600uf each.
Old 3rd March 2010, 12:02 AM   #107
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I am currently selling some tubes on ePay. I collected some sweep tubes, but since they are unique and not in current production I decided to sell them for those who want to use them. I will stick with GU-50 output tubes, there are still plenty of them. But 6LW6 and another similar tubes will go.
NOS 6LW6 vacuum tube - Admiral - eBay (item 180476307383 end time Mar-09-10 16:57:59 PST)
The Devil is not so terrible as his math model is!
Old 3rd March 2010, 01:13 PM   #108
tympani1d's Avatar
atmasphere:
Any chance you'd post power supply schematics for the M60's?
I think; therefore will NOT be Politically Correct.
Old 3rd March 2010, 06:44 PM   #109
atmasphere's Avatar
Here ya go... the transformers are proprietary and the usual copyright restrictions apply.
Old 3rd March 2010, 10:50 PM   #110
Those 120/240 1:1 ct's are good for america but if your on 240 all you need is a regular center tap. half of 240 gives you +/- 120 RMS. In this sense it *SHOULD* be cheaper for those of you on 240 by a few units (dollars euros pounds or what have you (rubels maybe))
as for the inductors triad might be your best bet if your trying to get your corner frequency way down.
Inductor; Common Mode; Ind 8mH; Cur 3.2A; Thru-Hole; DCR 0.12 Ohms $4.17 might be steep. how many inductors are we talking about here 2,4,8?
New to Tubes, just bought first tube amp josefgabriel Tubes / Valves 28 7th April 2010 07:20 AM
FS: 1626 Tube Amp, Van Alstine pre, tubes, crossover. xecluded Swap Meet 1 30th April 2009 07:27 AM
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
Adding more power tubes and make a tube amp switching them? Nicko_Lps Tubes / Valves 3 7th January 2009 12:31 AM
"The Fisher" tube amp 7189 output tubes laflamme Tubes / Valves 4 28th August 2004 12:40 AM
Copyright 1999-2017 diyAudio
