What tubes for a tube amp?
Old 7th March 2010, 08:17 PM   #121
mullardel34 is offline mullardel34  United States
Originally Posted by atmasphere View Post
Here ya go... the transformers are proprietary and the usual copyright restrictions apply.
atmasphere,
Oops! It looks like I may have misunderstood the power-supply configuration earlier in the thread, so I hope you can clarify a design point for me...
According to the power-supply schematic that you posted, it looks like the "floating" power-supplies for each "phase" of the output stage have only a single 99VAC secondary winding, providing 14OVDC. I had thought that each "phase" of the power-supply was a dual-secondary power-supply with a total of 280VDC (+140VDC and -140VDC), similar to the +/-300VDC dual-rail power-supply for the input/driver stage. However, the 200VDC-rating for the filter capacitors would certainly seem to imply that my new understanding is the proper interpretation (i.e., 140VDC < 200VDC = "good", 280VDC > 200VDC = "bad")...
Is my new interpretation (single 99VAC secondary winding, providing 140VDC power-supply for each "phase" of the "floating" output stage power-supply) correct?
Thanks in advance!
Mullard EL34
Old 7th March 2010, 11:24 PM   #122
Default M-60 OTL initial parts-cost estimate
Now that we have defined the unique-to-the-M-60 "big-ticket" power-supply components for the M-60 mono-block power-amplifier, I've defined an initial parts-cost estimate of ~$1200-$1500/mono-block. The following is the cost breakdown:
* Power Supply Components [~$500] - employing the Antek toroidal power-transformer models documented earlier in this thread, Hammond power-supply chokes, Nichicon high-reliability/105-degree-Centigrade power-supply capacitors and Solen polypropelene film-type power-supply decoupling capacitors, the estimated component costs for the M-60 power-supply is $502.75 (see attached Excel spreadsheet).
* Signal-Path Components[~$400] - I recommend following the best-practices used by Atma-Sphere Music Systems in construction and employ point-to-point wiring. To simplify and modularize the point-to-point wiring of the M-60, I suggest the use of single octal-socket terminal/turret boards such as the IAG TB-18's (Product Details) at about $17/each (see attached spreadsheet and illustration); we'll need 12 units per monblock (one for each tube). This approach allows us to pre-assemble each tube with the nearby components in the schematic, then simply install the "module" into the chassis. The pair of V-Cap Teflon coupling capacitors are an upgrade offered by Atma-Sphere and are used to bridge the input stage with the driver stage at almost $70/each. Add in the remaining Vishay precision metal-film resistors and Caddock metal-film power resistors, Zener diodes, film-type capacitors, etc., and we're up to about $380-$400 for the signal-path components (excluding vacuum-tubes). I use the usual suspects for DIY parts-vendors such as Digi-Key (DigiKey Corp. | Electronic Components Distributor | United States Home Page), Mouser (Mouser Electronics - Electronic Component Distributor) and Newark (US - Electronic Components Distributor | Newark.com).
* Vacuum Tubes [~$180-$320] - the necessary complement of vacuum-tubes (four 6SN7's, eight 6AS7's) can be procured from a number of sources. Some of my personal favorites are Tube Depot (Welcome to TubeDepot.com!), Tube Store (thetubestore.com Audio and vacuum tubes for your amplifier.) and Antique Electronic Supply (Antique Electronic Supply). The full complement of tubes from these sources varies between $180 up to about $250 (depending upon grade of tube specified). Of course, for a modest premium, you could just order the full set of tubes directly from Atma-Sphere Music Systems for about $320; that approach would safely ensure that the tube complement was appropriate for use in the M-60...
* Chassis Components [~$300] - This is the area where we'll likely see the largest divergence among those DIYaudio members who elect to build a pair of M-60's. As a long-term owner of Audio Research equipment, I'm heavily imprinted with the enclosed black anodized-aluminum lab-equipment chassis with clear anodized aluminum front-panel and black rack-mount handles. Therefore, I house my audio projects in a 14-Series chassis from Par-Metal (Par-Metal). I construct the internal structure for holding power-transformers, terminal-boards, etc., from pre-cut sheet aluminum and pre-cut aluminum bars ordered from Online Metals (Online Metal Store | Small Quantity Metal Orders | Metal Cutting, Sales & Shipping | Buy Steel, Aluminum, Copper, Brass, Stainless | Metal Product Guides at OnlineMetals.com). I usually have my front-panels and rear-panel overlays CNC-milled and engraved at Front Panel Express (Front Panel Express - Custom Front Panels with free Front Panel Designer*-*Home). The end-result is wickedly cool-looking DIY audio components.
Mullard EL34
Old 8th March 2010, 11:35 AM   #123
Originally Posted by markusG View Post
atmasphere> Just to be clear. You're saying run the heaters on the output tube supplies? Not an extra secondary but actually on the 140V? I thought the heaters were rated 6.3V?
VDC=VAC/sqrt(2);
It sounds familar...
MarkusG,
The filament heaters are still AC-powered separately from the DC voltage applied across the triode tube elements.
The formula for caculating DC voltage is:
VDC=VAC*sqrt(2)
Mullard EL34
Old 8th March 2010, 05:16 PM   #124
atmasphere is offline atmasphere  United States
atmasphere's Avatar
Originally Posted by mullardel34 View Post
atmasphere,
Thanks in advance!
Yes. In this way, the output is true push-pull, just like a transformer-coupled amplifier. That is to say, we don't have a cathode drivings the speaker in tandem with a plate. The output impedance is the same whether in push or in pull, if you don't mind the simplified explanation
Old 8th March 2010, 06:00 PM   #125
atmasphere,
Thanks for clarifying my misunderstanding about the power-supply structure; this information will permit us to use only one transformer to power both "floating" power supplies! This information also brings my estimated power-dissipation for a powered-up M-60 into alignment with the published specifications for the product on the Atma-Sphere Web site, so I'm more comfortable that I've now got my head wrapped around the M-60 gestalt.
I just love the operational symmetry of the output stage; this topology is just too cool; again, thank you for sharing this information for non-commercial use by DIYaudio members!
To the forum-members, my initial parts-cost estimate (posted a bit earlier in this thread) assumed this new understanding of the power-supply structure. A power-supply schematic that incorporates the off-the-shelf components for a buildable implementation will be forthcoming once I can satisfy a peak in demands from my "day job"...
Mullard EL34
Old 8th March 2010, 06:22 PM   #126
tympani1d is offline tympani1d  United States
tympani1d's Avatar
atmasphere,
YaHoooooooooooooo!! We're in rapt attention at the prospect.
Thank you!
I think; therefore will NOT be Politically Correct.
Old 10th March 2010, 08:07 PM   #127
Thank you!
tympani1d,
You're quite welcome! I'm about half-way through the first-draft power-supply schematic (I grabbed a few cycles for drafting the schematic over the weekend, while my family slept...), so it won't be too much longer before I can post the diagram.
To the DIYaudio forum members following this thread,
I need your assistance; can anyone read/identify the U1 part-designation in the M-60 power-supply schematic post by "atmasphere"? I know there are file-size limitations on posts, but the image resolution makes it impossible for me to clearly read the part designation on U1 (all I can ascertain is "V<something>-<three-characters>"...). If no one can identify the regulator chip, "U1", I'll just insert an inductor as a place-holder in the first-draft schematic.
Thanks in advance!
Mullard EL34
Old 10th March 2010, 08:52 PM   #128
markusA is offline markusA  Sweden
markusA's Avatar
All I can make out is V?-400. the ? can be a 0,O,D or B I think?
I'm fairly certain of the 400.
Old 10th March 2010, 11:37 PM   #129
atmasphere's Avatar
Its a VB-408- A high voltage regulator. We found that we had to use them when the amp had the switch in the class AB position. There was so much variation on the plate of V4, the regulator was needed to make the amp play right.
If you use a 3K 3watt resistor instead, the amp will work perfectly as long as you do not include any of the 'class AB' elements shown in the schematic.
The history is that when this amp was made, we had a distributor that wanted the extra feature installed. No-one ever seems to have used it. Fortunately, we're not involved with that mess these days and so we just do the 'class A' circuit exclusively. For that, the resistor above works fine- from 107 to 125V you cannot measure or hear any change in performance of the circuit.
Old 11th March 2010, 01:42 PM   #130
MarkusG,
Thanks, that's about all that I can see as well; hopefully, someone will be able to give us a more definitive answer as to the identity of U1...
In the interim, I'll just include an inductor as a place-holder for the unknown/unidentified three-terminal regulator circuit in the initial draft of the power-supply schematic. My current assumption is that the U1 circuit is a refinement of the driver stage operations, but that's just a guess on my part...
Mullard EL34
What tubes for a tube amp?Hide this!Advertise here!
New to Tubes, just bought first tube amp josefgabriel Tubes / Valves 28 7th April 2010 08:20 AM
FS: 1626 Tube Amp, Van Alstine pre, tubes, crossover. xecluded Swap Meet 1 30th April 2009 08:27 AM
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 10:01 PM
Adding more power tubes and make a tube amp switching them? Nicko_Lps Tubes / Valves 3 7th January 2009 01:31 AM
&quot;The Fisher&quot; tube amp 7189 output tubes laflamme Tubes / Valves 4 28th August 2004 01:40 AM
Copyright ©1999-2017 diyAudio
