diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Point to point or use a PCB (http://www.diyaudio.com/forums/tubes-valves/16110-pcb.html)
jarthel 6th June 2003 10:34 AM
well traditionally, tubes circuits have used point to point.
Well it's ugly for me and hard to "debug" if there are problems in the circuit. Is it possible for me to use a PCB for th resistors/caps and other parts and connect the respected points to the tube pins using wires? Any negative effect on using a PCB?
Thanks for the replies.
Jayel
dhaen 6th June 2003 11:30 AM
Why not? Lots of commercial designs use PCB's. Not because they're easier, but because they're cheaper in quantity.
Debugging? A hell of a lot easier with P2P!
Downside? Longer cables with PCB's. Some say that's a problem.
jarthel 6th June 2003 11:42 AM
This is subjective and since I've built circuits only on PCBs/breadboards for the past 10 yrs, it's easier for me. :)
any explanation on the downside?
thanks for the replies.
jayel
Tube_Dude 6th June 2003 11:52 AM
To loooooong.....
As tubes are high impedance devices ...long cables are more prone to noise and hum pickup...
jarthel 6th June 2003 12:05 PM
what if I twisted pair (the other wire connected to ground) for every wire going into the tube socket pins?
I guess this would help. right?
dhaen 6th June 2003 12:26 PM
Not sure where this is going..
[QUOTE]This is subjective and since I've built circuits only on PCBs/breadboards for the past 10 yrs, it's easier for me. [QUOTE]
Well, I have found considerable difficulty moving PCB traces:cannotbe:
Seriously, it is possible to get a better job all round with P2P.
Oh, and in case you think I'm a luddite, and not "PCB aware", here's one of mine:
Here's one of mine (not valve though)
Cheers,;)
edit: typo corrected.
dhaen 6th June 2003 12:31 PM
Not at all; Possibly the worst thing you could do. High impedance circuitry is sensitive to even small capacitance.
Have a look at the pictures of kit built by others to get some idea of the best (established) techniques. You are unlikely to better them, until you gain considerable experience yourself. So you may as well follow them.
pedroskova 6th June 2003 02:31 PM
Why not a P2P breadboard, and a PCB final? I'd keep ground P2P in the final since you're more apt to run into unforseen problems there than anywhere else.
Bas Horneman 6th June 2003 03:59 PM
John, I'll show you mine if you show me yours type behaviour is really not acceptable anymore these days ;)
What on earth was that for?
Bas
dhaen 6th June 2003 04:31 PM
Bas
I know it's Friday, but there's no point getting frisky:dodgy:
It's one of these......Blatent advert for someting no one on the forum would want :dead:
Resources saved on this page: MySQL 18.75%
