Point to point or use a PCB - Page 2 - diyAudio
Old 6th June 2003, 06:11 PM   #11
diyAudio Senior Member
fdegrove's Avatar
P2P or better still C2C.
Friday or not...over and out.
Frank
Old 10th June 2003, 03:50 AM   #12
There is no written rule you have to use all of one or the other. Many kits (like Consonance) use both topologies and they sound fine.
Old 10th June 2003, 09:09 PM   #13
jcarr is offline jcarr  United States
Wardsweb: Agreed. Analyze each circuit node for what kind of operating conditions it wants (constant impedance, low capacitance, shielding etc.), and give it a suitable environment.
I primarily rely on four-layer pcb construction (including ground and power planes), but add special structures (isolated stand-offs, p2p, floating isolated pads etc.) wherever appropriate.
hth, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 10th June 2003, 09:15 PM   #14
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Whichever you like
I use PCBs and P2P. They both have their advantages. PCBs can be good for RIAA stages because a double-sided PCB allows a ground plane. In the end, my choice is usually enforced by the components I want to use - some are designed for PCBs, others for P2P.
Downside for PCBs is the poorer dielectric (FR4 vs air).
What's far more important is careful layout...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Wire Wrap connections for point to point mashaffer Tubes / Valves 10 7th July 2007 01:11 PM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
aleph - any point-to-point builders? HeadSh0T Pass Labs 15 8th November 2004 09:35 AM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 08:11 AM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 10:59 PM
Copyright 1999-2017 diyAudio
