6EM7 SET Headamp
6EM7 SET Headamp
Old 10th February 2010, 11:10 AM   #1
regal is offline regal  United States
Default 6EM7 SET Headamp
Looking into adapting this to a headamp:Click the image to open in full size.
It has too much gain for a headamp so I would need to replace the battery bias with a resistor, I would also lower the output tube current and change the resistors to keep it DC coupled (haven't done those calculations yet.)
Anyway if I remove the battery cathode bias would this screw up the DC coupling capability of the amp? Possibly replace the first tube plate resistor with a CCS, which would give a stable plate voltage and stil 1/2 mu with an unbypassed cathode?
Old 10th February 2010, 11:50 AM   #2
Gluca is offline Gluca  Italy
Gluca's Avatar
you may consider this schematic. it is something I am listening now and I am very pleased with. 6EW7 is quite similar to 6EM7. Gain is again high but I need it all as I am stepping up the signal out of my DAC.
I will move the choke from the upper triode V2 down to the lower V1 and use the CCS on the V2. Things should get better this way.
I R loaded the V1 as in kaufman schematic but the amp now sounds way better. AC filament elevated to 100V, no hum whatsoever.
gianluca
Old 10th February 2010, 12:11 PM   #3
gianluca
Wow interesting tube DAC stage, makes me wish I hadn't given up on tubes for DAC's. You must be using a very nice low I/V resistor which is great for the DAC, no hiss?
Old 10th February 2010, 12:20 PM   #4
Gluca's Avatar
I am running the PCM1704 into 22ohm+22ohm (balanced DAC with multiple chips in parallel) and using a 600:50k mic in transformer.
6EM7 SET HeadampHide this!Advertise here!
Next project 6EM7 mashaffer Tubes / Valves 31 28th September 2008 04:13 AM
6EM7 Amp jaymanaa Tubes / Valves 12 24th July 2008 03:01 AM
first post, PS for 6em7 SET amp spgjmf Tubes / Valves 4 20th March 2008 07:36 AM
yet another 6em7 amp rman Tubes / Valves 6 17th October 2007 01:26 PM
Copyright ©1999-2017 diyAudio
