diyAudio Sponsor
Old 10th February 2010, 12:06 AM   #31
pointy is offline pointy  United Kingdom
pointy's Avatar
And therefore it also functions like the machine gun on a first world war biplane shooting through the propeller.
.................................................. ......2nd base chalk dust
Old 10th February 2010, 12:48 AM   #32
pointy's Avatar
So g2 becomes invisible like the propeller.
Old 10th February 2010, 12:54 AM   #33
Originally Posted by vega65 View Post
Sorry for the hand drawing.
I use this circuit in the g2 supply of a 13E1 Se.I was recommended this circuit by 7N7, who used it in the g2 supply of a pentode cathodefollower.
Initially I had S130P (pre ww2 vr tube) but it was not performing as well as the other vr tubes in the amplifier( driver tube is pentode with 0c3 in g2 supply, unbypassed cathoderesistor).
The amplifier delivers 32-34 w .
THD 1,2 % at onset of clipping.noise on output with 1 k termination on input, is 400µv.with the 400 hz filter connected around 100µV.
As a newbie many things is unclear.can anyone explain if the cap from collector to ground is needed when b+ is regulated ?
Vega,
Coming in a little late ..... that cap has nothing to do with B+ regulation. In your sketch the collector (I presume the lead going to screen is the emitter) has signal on it coming from the OPT; the capacitor is to bypass that.
As your drawing stands, it rather looks like a UL type arrangement for a screen at lower voltage for a power amplifier. I cannot quite read the value of the emitter capacitor. Is this circuit supposed to have something to do with lowering noise?
Old 10th February 2010, 01:15 AM   #34
Originally Posted by Wavebourn View Post
I once significantly reduced noise powering 6J32P filament from 5V voltage regulator.
A lower cathode temperature can give lower noise, especially in small-signal cases. In a manner of speaking, decreasing the electrons 'rushing past' while they are not used (needed), lowers their 'noise effect.' I have done this occasionally, but never tried to optimise. It could well be that such an effect might be sensitive to cathode temperature, which might mean some heater voltage stabilization might be needed. But then in all probability there will be dc on heaters as the subject would only be of concern at low signals - in which case stabilization is possible. (ICs are cheaper than big electrolytics, so make good ripple eliminators in addition to regulating.)
Not sure whether already mentioned (I did not peruse all posts), but did anyone experiment with value of screen voltage? Gain goes down with screen voltage, but is this linear?
Old 10th February 2010, 07:34 AM   #35
vega65 is offline vega65  Norway
First my apologies to threadstarter. It was not my purpose to post of topic.I was in a hurry and did not present my thoughts clear enough.
You ask how to best treat g2.
The circuit shown is not mine .I got it from Paul Leclerc (7N7 at forum)
He has been kind enough to give me some advise as I have progressed in making a 13E1 Se amplifier.
First i tried a vr tube for g2 of output tube.But it was noisy and unstable. Paul proposed the attached circuit as a way to keep g2 voltage in step with the cathode voltage.I have installed the circuit in my outputstage.It did clean things up.I am not sure how well it performs as I am almost a newbie and don't understand the meaning of everything I see on my scope and meassure. But Thd went down almost 1 % compared with the vr tube.
Others are better qualified to judge about this way of treating g2.
I am sure you can use this circuit in a pentode inputstage as well.I intend to try it there as well.But there has been to little time for soldering the last weeks.
Johan : the lead going to the screen is the emitter.The cap value there is 0,47 µF.
I am sure Paul think it is ok I post the circuit here.It was originally used in his "instock " amplifier in the g2 supply of a cathodefollower.The circuit is somewhere on this forum
Dual HF small signal pentodes ? Arnulf Tubes / Valves 4 26th September 2009 05:05 PM
PC for a source. Help lowering PS noise. HaLo6 Digital Line Level 22 12th February 2009 03:58 AM
Grid Leak Bias on small signal pentodes. Shoog Tubes / Valves 18 9th November 2007 12:48 PM
Lowering Aleph PSU noise tortello Pass Labs 0 4th October 2001 09:52 AM
Page generated in 0.10132 seconds (76.93% PHP - 23.07% MySQL) with 11 queries
