| diyAudio Sponsor | ||
Hello wise guys
I build a LTP using a simple CCS at the tail to create a phaseinvertes and highly symetrical signal. Driving performance is not need but it should symetrical as possible. It works fine! I add for every phase a simple cathode follower to get an low impedance output ( ~600 Ohm ). Unfortunately if I connect the cathode follower to the LTP the amplitude of both stages ar heavy different ( one is ~ -6dB ). I do not understand this issue because the Zin of the cathode follower are ~ 8Meg which should not load the LTP. Any tipp for me??? Sorry Iīm a beginner in tubes ( but not in electronic Bestr regards Karsten |
#2 |
OK, let me earn this beer.
First, a general observation- if you're going to use an ECC83-type of tube, you need MUCH higher plate load resistors. The huge second harmonic will largely cancel because of the push-pull operation, but third and fifth will be pretty high. You want at least 100k, and much more if you can manage a nice, large B+ rail. 300k isn't too high. Second, you can make things simpler and solve your problems simultaneously. Get rid of the resistor in the cathode (R4). Ground the far end of the grid leak resistor (R1) instead of returning it to the cathode. Ground the other grid (getting rid of the 1M grid leak for that half). Your grid stoppers can be greatly reduced- 1k is more than enough.
Listening to records is like ****ing a picture of Brigitte Bardot. - Sergiu Celibidache |
#3 |
Hey Sy,
O.K. beer is reserved for you :-) Best of german beer is "Flensburger" for my opinion ( Town in the verry north of Germany ). I tried your advice to ground R1 grid leak resistor. Also I ground R8 instead to connect it to R4 ( cathodes of LTP ) and leaving both grid stopper ( yepp, will reduce them to 1K ). Well, donīt work. The signal amplitude at both plates are quite different now. Also I do not have any bias ( no current through R4 ). On all examples of LTP I have seen the Grid-leak resistors was connected "behind" the bias resistor and the long tail resistor to ground. This is replaced by the CCS and works fine for me but have the issue with the cathode follower ( Is there a common abbrevation for "cathode follower in english ? ) Concerning your first hint about harmonic distortion. I choosed the ECC83 ( 12ax7 ) because I would like to get a most linear out ( itīs simply the out stage of all the tubes before ). The best case will be to have no or less amplification. I choosed the bias to 1V to get middle workping point on a loadline Va=200V / Ra=68K. HT is ~ 250V and for the long-tail I assumed ~ 50 V.The question is why the cathode follower bred the LTP out balace concerning the signal amplitude? Thanks a lot for your help! Regards Karsten P.S. sorry for my bad english... |
#4 |
My apologies; I hadn't noticed that you'd returned the CCS to ground instead of to a minus rail. That means your biasing won't work- you're not actually running constant current. If you want to DC couple the input at DC ground, and likewise have the other grid at DC ground, the CCS won't have enough headroom to operate. The CFs are innocent bystanders.
Two choices. Best would be to use a low voltage DC rail (-9V is more than enough), then return the input grid leak to ground as I suggested and return the other grid to ground (no 1M resistor and no biasing resistor!). The other choice is to capacitor couple the input so that the tube can "float" on a few extra volts, then using a bias resistor, return both grids to the "floating" potential.
#5 |
Yeahh, and me too. I used all time a capacitor to couple the input. Sorry, donīt updated the schematic.
So we are back to my origin issue. The LTP and CCS works fine without to connect the CF to the anodes of the LTP. Without the second tube ( ECC81 ) the Anodes of the LTP are connected via C2, R10, R11 and R13 to ground. For that there is a load (AC concerned) of 1.022Meg. With this load the LTP works fine.The CF should have a Zin of ~7.5Meg. For that I do absolutly not understand Why the amplitude of both phases are different. I wonder that one stage have 1/2 less amplidue... Itīs magic for me... Any ideas? Regards Karsten |
#6 |
Well, it doesn't really matter what the CF impedances are as long as they're the same. If you see an imbalance, that means you've made a wiring mistake or accidentally used the wrong value resistor somewhere.
#7 |
So,Iīm not to stupid to think that this schematic should work?
Wiring is O.K. because I use a program ( Eagle) and a PCB. Itīs much load to route and make a PCB for a Test-board. But itīs quite more secure.. Also I double checked the resistor values.. Everyting O.K. Itīs possible to have a Tube which is quite unbalanced at the systems? 20% is a "normal" difference but 50%. Furthermore the bias on both systems via R12 and R17 ( 2,0V at 560Ohm are the same )... Really strange.... Karsten |
#8 |
Take a look at my recent post on LTP balance. If the CCS is working, the tubes can be fabulously mismatched with no effect on balance.
#9 |
Yepp, I folowed the thread. Thatīs why I use the CCS at the LTP.
Well, itīs the CF or better the coupling between the LTP and the both CF which do not in balance. Just run the CF without coupling to the LPT and feed them with the same singal amplitude I get the same amplitude at the output. So I can assume that the systems of the CF within the Tube are quite similar. There must be a strange thing while coupling the LTP to the both CF... O.K. I try to change the couple "C"īs ... |
#10 |
O.K. lost for today. Itīs late in the night, better to stop here.
Thanks a lot for your help! Regards Karsten |
| CCS loaded DHT cathode follower? | leadbelly | Tubes / Valves | 0 | 20th January 2010 01:09 AM |
| 12at7 LTP CCS | wicked1 | Tubes / Valves | 11 | 23rd April 2008 08:28 AM |
| Tube LTP CCS? | kegger | Tubes / Valves | 23 | 12th August 2006 01:03 AM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 06:47 PM |
| Page generated in 0.13047 seconds (83.61% PHP - 16.39% MySQL) with 11 queries |
