diyAudio Sponsor
Old 6th February 2010, 01:19 AM   #1
Default Aikido All-In-One Octal Heater Troubles
I'm using all 6SN7GTB.
Initial readings:
HV AC input is 236.3VAC
B+ voltage is 307VDC
Heater voltage is 6.2V
Slight hiss from both speakers, slight buzz from right channel.
Sounds really good playing music but when I stop the music after a few minutes to switch to a new song, I notice the hiss volume is much louder and my left woofer is oscillating. Immediately shut off the power amp (did not wait to see if right speaker was doing it too) and measure voltages.
Now my heater voltage is 2.1VDC and the filaments are no longer visibly glowing. I did notice the regulator heatsink (1.5"Wx1"Dx2.5"H) gets really hot. My IR thermometer sees temps well over 180F.
Looking at the documentation, I'm confused. There's a Filament Jumper Wire Schedule that shows the configuration for a 12.6V PS with 6.3V tubes. I've jumpered that configuration.
On the next page is a table of typical part values. I've chosen the parts in the 6.3V Heater Voltage column.
For Vac Input, 7-8Vac@ 5A and 12-12.6Vac @ 2.5A options are listed.
I'm using a toroid on which I wound a 20 gauge 12V secondary. Max RMS current density is 4.9A/mm2 (=2.53A) and DC current density is 2.4/mm2 (=1.29A).
What did I do wrong?
Old 6th February 2010, 03:19 AM   #2
john65b is offline john65b  United States
john65b's Avatar
I have the exact same setup. Your issues are most likeley around your heater circuit.
First question i do you have AC or DC on heaters? Regulator? A 7806? I beleive a Regulator is usable only with DC, not AC.
How did you ground your heater? I floated mine with a cap as suggested in the Aikido Octal manual.
If DC Heaters, check your rectifier-smoothing cap arrangement...
Actually, I also initially had a 7812 regulator on my 6SN7 heaters, but current was too much and got hot, and burned up, so I put in a resistor ( I was using Rat Shack 12VAC Trannies -> DC on heaters). I bet you fried your regulator due to filament currents, just use Ohms law to figure resistor instead of regulator.
Keep it simple - Tranny, Full Bridge rectifier, 10,000uf 16v cap, resistor, to heaters.
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V
Old 6th February 2010, 03:32 AM   #3
LD1085V. The filaments are being fed with DC.
I'm using the all-in-one kit that has both power supplies and the preamp circuit on a common PCB. The only connections are heater ac, hv ac, input and output.
Old 6th February 2010, 03:39 AM   #4
I'm composing an email to JB and it occured to me that I could configure the heater supply and filament wiring in multiple ways.
Currently, my 12Vac is being turned into 6.3Vdc by the regulated supply and the heater socket pins are jumpered for a 6.3Vdc supply.
But perhaps I should configure the supply to produce 12.6Vdc and change the filament wiring for a 12.6Vdc supply feeding 6.3Vdc to each tube.
Old 6th February 2010, 04:18 AM   #5
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
It sounds like maybe your heater supply regulator went into thermal protection and shut down. Is it working now? It probably needs a better heatsink.
Old 6th February 2010, 04:31 AM   #6
I adjusted the regulator to output 12Vdc and rewired the filaments to suit and have a much cooler and happier regulator.
Much better. Now I just have to hunt down the source of that buzzing in one channel. For the time being, I can ignore it.
Thanks.
use 120V x 2 for Aikido octal transformer? ultrachrome Tubes / Valves 3 31st January 2010 07:05 PM
Regulated Heater on the 6SN7 Aikido Plate to Heater question john65b Tubes / Valves 6 24th November 2009 05:44 AM
FS Aikido Octal linestage $75 nvrgdenuf Swap Meet 2 29th December 2008 08:35 PM
Calculating PS current for octal Aikido jrebman Tubes / Valves 4 25th March 2008 08:47 PM
Octal Aikido? What tubes? jayme Tubes / Valves 8 31st December 2006 03:03 AM
Page generated in 0.08830 seconds (76.88% PHP - 23.12% MySQL) with 11 queries
