diyAudio Sponsor
Old 7th February 2010, 05:45 AM   #11
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
I am working of a EF184 with servo bias actually. 6SN7 was there just to understand how things go.
Old 7th February 2010, 06:24 AM   #12
tarmac ripper
Gluca's Avatar
OK, a schematic is worth 1000s words
Gianluca
Old 7th February 2010, 07:23 AM   #13
cetoole is offline cetoole  United States
That isnt a servo, and I really dont think it will what you want at all. You should get more like 70ohm input impedance at the cathode of the ef184. Also, I cant think that it will be happy with a 470ohm plate load.
Old 8th February 2010, 02:08 AM   #14
tarmac ripper
Gluca's Avatar
I am probably very wrong, but do you mind elaborating a bit your comments?
Old 8th February 2010, 03:40 AM   #15
The opamp isnt working as a DC servo at all, no integration cap or input resistor, so therefore the whole circuit wont work as you are expecting.
Old 8th February 2010, 05:22 PM   #16
tarmac ripper
Gluca's Avatar
umpf ... I stand corrected. And the load onto the dac is in the 50ohm ballpark: too high. I-ll look somewhere else.
Old 9th February 2010, 02:34 PM   #17
You wont get the input impedance any lower without more transconductance, or some nfb. EC8020 would be fun. How do you feel about a bit of sand, MOSFET/triode CFP would really drop it down.
I use something kinda similar in my system, but using BJTs for an open loop common base amplifier.
Old 9th February 2010, 03:45 PM   #18
tarmac ripper
Gluca's Avatar
Sand is welcome: I am putting all the parts together for a rboer IV. For the time being I am more than happy with a R (22ohm) and a step-up transformer into a tube preamp. I just want to explore other possibilities. It's fun.
Old 9th February 2010, 04:08 PM   #19
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Sorry for the off-topic. But what is a rboer IV?
Old 9th February 2010, 04:32 PM   #20
tarmac ripper
Gluca's Avatar
Simple I/V for TDA1541
many variants and updates exist.
ciao
Transimpedance (current drive) chipamp schematics? OPA549? swak Chip Amps 0 14th February 2007 12:32 AM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 17th May 2005 12:58 AM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 02:50 AM
Page generated in 0.11517 seconds (78.66% PHP - 21.34% MySQL) with 10 queries
