| diyAudio Sponsor | ||
While looking over the schematic for this OTL amplifier I noticed something odd.
Lee 6C33C OTL It looks fairly straight forward until you see +/- 180v power supply. Its really not a split supply. The output from the tubes goes through the speaker and then to the middle of the two 1000uf caps. Most other OTL amps have a true split supply with the center being ground. The link to the original article is long gone although I recall seeing it years ago, say 1996 or so. So any thoughts or opinions on this design? |
#2 |
No expert (by any means) but the PI on this looks way cool -- is it 1/2 triode / 1/2 pentode? -- my little brain is reeling. What *is* that 12BY7 doin' in this circuit? I gotta play with this topology as a driver toward more common tubes like 6aq5s, 6x6, el84s. Any thoughts on that would be of real interest to me.
But on the PS issue -- is the 6c33c tube (aside from crazy high output/plate) worth all the trouble?? Is there a 6c33c evangelist in the house?!?! Wow -- straange iron -- maybe he is hiding others under the covers but if not -- that is one multi-tap xformer - huh? Not sure I know enough to appreciate the implications of the +/- 180V - but it is different. Very cool schematic -- thanks for posting it.
"Life is hard -- afterall it kills you ..." Katharine Hepburn Last edited by moonbird; 5th February 2010 at 07:19 PM. |
#3 |
The output is connected to the junction of the two caps at ground. Nothing at all unusual there.
The 12BY7 is a current sink, with feedback to the cathode from the output.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
Magneto the Gravity Man
The caps could do with balancing / discharge resistors
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#5 |
Yeah, if the bias current of the two 6C33 is not perfectly matched, those capacitors charge up toward one rail. Needs some zeners/ resistors across them to handle bias current mismatch.
The other thing I notice is that one 6C33 is operating as a follower, and the other is operating with gain. Needs a bootstrap resistor/cap from the output back to one of the 12BH7 plate load resistors (top end) to equalize output gains. I also see a 20K Ohm pot from the output back to the 12BY7 cathode, that is modulating the tail current for the 12BH7. Maybe this has the effect of equalizing the output tube gains, strange way to do that. Variable slew rate.
Ohms Law V = I R Last edited by smoking-amp; 5th February 2010 at 07:38 PM. |
#6 |
Hi Don;
another option is to turn the bottom tube in a linear voltage to current converter. Kind of Pyramid-III concept. I did similar things with 12L6GT, with capacitive coupled auto transformer, before coming to conclusion that power MOSFETs are much more optimal to drive modern speakers than any tube you can find/design/build.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#7 |
R.I.P.
I don't like the circuit as there is no designed in way to have the lower output tube have exactly the same gain as the top tube, i.e.slightly less than one.
The OTL in the latest copy of "Audio Express" is the best OTL circuit I've ever seen, very low distortion without any NFB, because he uses the lower output tube as a gain defined anode follower. Wll thought out, good design! Regards, Allen |
#8 | |
Andy .
#9 |
As requested.
#10 |
| I need help of Lee Basham | rafelo | Solid State | 1 | 19th June 2007 01:13 PM |
| Does anybody know Lee Jackson | vytas | Solid State | 0 | 5th February 2004 09:30 AM |
| Otl ? | woody | Tubes / Valves | 2 | 11th September 2003 04:44 PM |
| Page generated in 0.10219 seconds (81.22% PHP - 18.78% MySQL) with 11 queries |
