diyAudio Sponsor
Old 3rd February 2010, 06:40 PM   #1
leadbelly's Avatar
Default What makes a great concertina triode?
Question as above. What is most important: high transconductance, low plate resistance, or something else? What about less important factors such as mu?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 3rd February 2010, 07:35 PM   #2
vinylkid58's Avatar
I may be wrong, but I read a post where Eli mentioned the 12AU7 as having the best characteristics for concertina duty. In some applications, maybe you could use other tubes, 12AT7's, 12AX7's etc.
My PP EL84 amp was designed with 12AX7's in the concertina, which I quickly removed in favour of 12AT7's that sound better to me.
Jeff
Old 3rd February 2010, 07:51 PM   #3
aardvarkash10's Avatar
kinda depends on whether it is just splitting or if it is also carrying out driver duties as well. Also what it is driving into...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 3rd February 2010, 07:53 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
The best phase splitter is when Concertina drives LTP. A sweet pair combination.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 3rd February 2010, 09:20 PM   #5
SY's Avatar
The best concertinas have matched loads under ALL conditions. That means interposing something between them and any stage that will transition out of class A. The LTP that Wavebourn mentioned is a good one- also see the very clever Williamson circuit.
High gain, high transconductance, and low distortion, that's what you want. 12AU7 is not good in any of these categories. 12At7 is better but not ideal. Something like a triode-connected D3a or 7788 is near-ideal. A 6DJ8 is a good compromise practical choice.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 3rd February 2010, 09:25 PM   #6
leadbelly's Avatar
Thanks SY!
Old 4th February 2010, 12:22 AM   #7
Jeff
Jeff,
You misconstrue my remarks. I stated that cathode followers and "concertina" phase splitters were the only jobs the 12AU7 is suited to. As SY stated, there are any number of types better than the 'U7 in those roles. I abominate 'U7 section voltage amplifiers.
A "concertina" phase splitter is a tricked out cathode follower. As such, high gm rates (IMO) 1st. In spite of its μ of 22, the ECC99 is good for the job, thanks to high gm and low RP.
Eli D.
Old 4th February 2010, 12:42 AM   #8
Wavebourn's Avatar
Right; in both cases common mode errors are minimal due to Concertina usage. Common mode errors cause syn-phase currents in output tubes that waste power. But in Williamson case 2 coupling caps are needed; in mine only one. It gives a possibility to stabilize working point using output from the long tail to the screen grid of the 1'st pentode; also my pentode LTP is convenient to drive linearized by parallel feedback by voltage output tubes that working as pentodes with low Cmiller have lower output resistance than triodes may have. Such a way wider frequency band may be obtained from output transformers, also phase intermodulations are minimal.
However, in my case Concertina + LTP form an APF, so big time constant is needed for stability on low frequency end.
An advantage of Williamson is possibility of better balance of amplification factors between 1'st tube and a driver, so choice of the 1'st tube and it's regime is less critical. Common triode may be used, while in my amp a very linear pentode stage is required.
Old 4th February 2010, 01:08 AM   #9
vinylkid58's Avatar
Sorry Eli, I am the misconstruer. After two days of struggling to rid this computer of malware & trojans, my head is spinning, therefore I shouldn't be quoting anyone.
Is there any way of implementing CCS in the concertina of my HK A224, or is this just a waste of time?
Thanks,
Jeff
Old 4th February 2010, 01:20 AM   #10
Wavebourn's Avatar
Uhm.... Jeff, who made such a thingy with feedback from OPT to Concertina?
It needs to be thoroughly discussed...
Lundahl+EL84 PP+concertina+input stage trifidmaster Tubes / Valves 63 21st December 2008 12:50 PM
Concertina Parafeed, or How to mess with OldEurope's mind... kenpeter Tubes / Valves 25 5th July 2008 02:04 PM
Concertina sanity check PeteN Tubes / Valves 12 27th June 2007 03:54 PM
JRC4558, please tell me, what makes them so great? MrGuitardeath Instruments and Amps 2 23rd November 2004 05:09 AM
What makes a *great* rock speaker? leadbelly Multi-Way 51 6th August 2003 01:13 PM
Page generated in 0.13578 seconds (82.57% PHP - 17.43% MySQL) with 11 queries
