| diyAudio Sponsor | ||
Does anyone know the use and wiring for the three leaded Russian PIO caps on EBAY. I know what to do with a filter-type cap that has a shared common lead (ground it) - but I guess I am too stupid to figure out a use for the lower value caps like .1uf?? Could these be used to as "mixer" coupling caps to merge like a reverb section signal with a dry signal?? Or even stranger perhaps a "splitter". Can someone think of a more clever use?? Thx.
"Life is hard -- afterall it kills you ..." Katharine Hepburn |
#2 |
Can you provide a link to these capacitors. I looked around on eBay but couldn't find them.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
Heres a couple:
2 x 0.25uF 1500V PIO CAPACITORS KBG. Lot of 4 - eBay (item 200432863436 end time Feb-02-10 21:53:45 PST) Paper + Oil Capacitor KBG-MP 2N 2x 0,25uF 600V QTY=3 - eBay (item 250370382010 end time Feb-03-10 07:56:01 PST)
#4 |
It looks like two caps in series with the center of the two being the case. Useful for bypassing something to ground I suppose... Have a few in my junkbox that are similar and even some with three sections.
#5 |
Yes, they have 2 caps inside, with one common leg connected to the case.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 | |
Datasheet states Paper low voltage low frequency capacitors. Alex |
#7 |
The problem with KY40's&42's has been the ungrounded metal case, it tends to pick up interference from other components and can lead to oscillations. Being able to ground the case with a lead is much nicer than trying to solder a wire to it.
| Russian PIO caps. Should I use them? | G | Tubes / Valves | 70 | 24th May 2012 12:07 PM |
| 2.2Uf PIO Russian capacitors | gaborbela | Swap Meet | 1 | 5th January 2009 02:54 AM |
| WTB: (4) .1uf/400V+ K40 Russian PIO Caps | mrdon | Swap Meet | 0 | 27th August 2008 03:23 AM |
| looking for 1uF at least 200V Russian PIO | jarthel | Swap Meet | 2 | 10th June 2006 07:23 PM |
| FS: Russian military PIO caps 0.047uF/1000V | reaction | Swap Meet | 10 | 14th December 2004 08:27 AM |
| Page generated in 0.09478 seconds (76.32% PHP - 23.68% MySQL) with 10 queries |
