| diyAudio Sponsor | ||
So im looking to build a cheap 1-2watt very small mono desk amp.
Something like a 50EH5 or 6T9 (still accepting recommendations) What im really after is a speaker for the project. The cabinet needs to be the foot print of a clock radio (smaller then 10" by 6" preferred) and it only needs to play radio freq range (100-120hz to 15khz or so) and is only going to be 3ft away from the listener. Any recommendations? I was thinking of a tangband or fostex. These seem to fit the bill but all the cab designs are huge and are designed to play down to 60hz. |
#2 |
How about some of the OB speakers gainphile has built? You could also go cheap with a Tangband full-range or expensive with the Jordan JX92S. You might want to ask your speaker questions in the appropriate speaker forums on this site. You'll have a higher chance of getting useful answers.
For the amp, you should be able to get 4-5 W out of a 6LU8 (or probably 6T9) spud in UL mode. I'll be posting the final design soon. You can get a primer here: 6LU8 Spud RFC. You could also look at the Tubelab SimpleSE. ~Tom |
#3 |
The simple se is in the works. However it will be over $300 and be 20lbs. Im looking for something very small to put on a desk at work that will replace my beloved clock radio (old tube radio that got dropped and shattered into a million pieces).
#4 |
You want baby Amp
Baby SET Pics: Classic Valve Design - Chinook S.E.T. Amplifier There's a 6AH4GT version earlier in the thread too. Cheers! |
#5 |
For the speakers I built the micro-fonken by planet10 full range. I was really surprised !
Best Regards, Davide |
#6 | |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Well since the big guy replied. If i was to make a uFonken, do i just buy a fostex of the right size from madisound and call it good, or is there a small baffle step cross over i dont know about?
#8 |
can't you save the driver from the radio? being old there is a chance it's a nice alnico
#9 |
Planet10, I never had time to thank you, but that speakers are really amazing.
D. |
#10 |
I did them with the standard Fostex and plywood I paid 3 $. I think it was the only project I made without spending a fortune.
D. |
| The ultimate mixing desk - ? | brikworm | Digital Source | 3 | 19th December 2009 10:43 PM |
| Desk Maintenance.. | jethdub | Parts | 16 | 20th February 2008 04:50 PM |
| Speakers in a desk... | ctardi | Multi-Way | 8 | 27th February 2006 09:00 PM |
| What is the best speaker for 120 watt and 80 watts | martin88 | Multi-Way | 6 | 10th December 2004 07:09 PM |
| Calrec - AMS VCS desk and AMS-Neve Libra Live desk | chrisbeech2 | Solid State | 0 | 15th January 2004 08:07 PM |
| Page generated in 0.10203 seconds (79.05% PHP - 20.95% MySQL) with 10 queries |
