| diyAudio Sponsor | ||
i have a psu using 6D22S in a graetz-bridge arrangement feeding a choke input supply. transformer is 500V output after input choke is 460V. the 6D22S have a separate 12V non-centre tapped filament transformer they are connected in series. I had a problem with the solid state diodes regularly blowing on one 'leg'. eventually the problem was traced to a 6D22S that was arcing. i replaced the tube and all seems well so far. i would like to connect the cathodes to the heaters. how do i do this with a non-CT heater transformer and a series heater connection?
#2 |
I'd connect one side of the heater winding to the cathode through a 10K to 47K resistor - they'll be at the same voltage, but the resistor will help filter common-mode noise. Either side of the heater winding will do - there's plenty of insulation.
| Regulated Heater on the 6SN7 Aikido Plate to Heater question | john65b | Tubes / Valves | 6 | 24th November 2009 05:44 AM |
| 6D22S Getter Question | Ardee | Tubes / Valves | 5 | 27th September 2006 09:35 AM |
| How to use Svetlana 6d22s? | protos | Tubes / Valves | 3 | 3rd February 2006 03:51 AM |
| Heater Question | lpd | Tubes / Valves | 4 | 20th February 2005 05:35 PM |
| Svetlana Svetlana EL509-II: Please disregard all my statements about this tube! | Morgan L | Tubes / Valves | 2 | 30th January 2004 06:15 PM |
| Page generated in 0.05695 seconds (68.66% PHP - 31.34% MySQL) with 10 queries |
