| diyAudio Sponsor | ||
Here is a unity-gain push-pull EL84 power buffer that I'm thinking about.
It uses local feedback from the output tube's plates to the driver tube's plate for unity gain. The LL1540 input transformer can handle 7.75V input (20dBu) for 0.1% distortion at 50Hz (however, more voltage can be applied with increasing distortion, eventually having 1% distortion at 24V). Using 300V B+, the output stage maximum output is about 12V (peak-to-peak). Therefore, operating the amplifier to full power in unity-gain mode, the input transformer will need to pass 12V p-p, which shouldn't be a problem. Alternatively, the feedback can include the output transformer's primary by using the UL tap. This gives the buffer a gain of about 2 (determined by the exact location of the UL tap, usually 40%). The means the input only needs 6V p-p drive. Any comments, suggestions, or critiques? |
#2 |
Whoops. Fixed cathode resistor in the driver stage (shared resistor instead of separate resistors).
Now has overall gain of 4V/V (12dB) when using UL taps, or 2V/V (6dB) when connected directly to EL84 plates. |
#3 |
this looks like what im looking for (gain of 2 version). However im confused on the ul tap (round thing with a 300 on it) as to were it goes. Im also confused on size/voltage requirements for hte passives, and what the load of the transformer needs to be (3k 5k?).
Also have you looked at millets 6B4G with 3vrms in? Thats about 8.5vpp. http://www.pmillett.com/6B4G_push-pull_amp.htm Last edited by nightanole; 8th February 2010 at 06:27 PM. |
#4 | |||
I haven't actually tried it out yet. I have the circuit built, but haven't applied power to it and listened. I'm curious if the feedback mechanism of connecting the driver's plates to the output's plates is actually feasible. |
#5 | |
Eli D. |
#6 | |
#7 | |
Yes, it is. BTW, get rid of the 12AU7. It's non-linear. You should be able to use the same passive parts with a tube from the 6FQ7/6CG7/12BH7/6GU7 group.
Eli D. |
#8 |
Pardon my ignorance. What are some advantages of using PP in a buffer. Is it less distortion? More linear?
#9 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 | |||
However, in this "exoliner" setup, the dominant tube is the output tube (EL84). Quote:
I have the amplifier running right now using 12ATU on the driver and EL84 on the output, using Edcor 8k transformers and about 290V B+. It could handle a bit more B+. I'm running the 12AT7's plate from the UL tap, so the transformer is included in the feedback loop. You can see on the schematic where the 12AU7's plate can be partially connected straight to B+ and partially to the UL tap. This way, the amount of feedback can be controlled. I just took out the resistor going to B+, so it operates fully in exolinear mode. I also put pads on the circuit board to choose the desired configuration. |
| EL84 push pull | slideman82 | Tubes / Valves | 4 | 19th June 2009 03:40 PM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| Unity Gain Tube Buffer | AKSA | Tubes / Valves | 41 | 2nd January 2004 10:11 AM |
| Opamp + buffer, how to bypass buffer at HF for unity gain? | Christer | Solid State | 10 | 29th October 2003 06:50 AM |
| unity gain push pull output stage | ergo | Solid State | 11 | 6th January 2003 10:32 AM |
| Page generated in 0.12534 seconds (81.92% PHP - 18.08% MySQL) with 11 queries |
