diyAudio Sponsor
Old 31st January 2010, 07:43 AM   #31
planet10's Avatar
Originally Posted by Geek View Post
It's what Planet10 has in his living room now.
Indeed And thourougly enjoying it.
Next i gotta get Duo to stop MooseFET from being MooseFART. Manual change of inputs is a bit of a pain, and daunting for all but me (or i could get off my butt, put 6H23pi in Fornaco and use it. MooseFET is cuter thou.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st January 2010, 07:49 AM   #32
Geek's Avatar
It's under lifetime warranty for you, Dave... I'll do it.
All he has to do is pull the muting transistors with vise grips and done!
That's the **only** diff between yours and mine (besides the PS) and since I can't duplicate it on mine, it has to be it.
Cheers!
Old 31st January 2010, 10:35 AM   #33
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
The Vreg still sucks...
Old 31st January 2010, 11:24 AM   #34
Geek's Avatar
The Vreg is straight off the National datasheet... blame them
Cheers!
Old 31st January 2010, 11:26 AM   #35
Duo's Avatar
With that big cap slugging the feedback loop down?
Old 31st January 2010, 11:29 AM   #36
Geek's Avatar
What big cap?... 10uF to ground after the 317 is nominal
You looking at the main filters?
The 10uF across the Vadj resistors? Nominal too (page 9, LM117 DS).
Cheers!
Old 31st January 2010, 11:30 AM   #37
Duo's Avatar
Can you show me the schematic for moosefet? Maybe email it to me?
Old 31st January 2010, 11:35 AM   #38
Geek's Avatar
Done!
Old 31st January 2010, 11:56 AM   #39
Duo's Avatar
I don't think the mute circuit is causing the problem. The exhibited sound was a hum, 120Hz, which occurred during brownouts as the line voltage rose back to normal. This is normally indicative of regulator dropout. Are you certain the transformer voltages are as listed in the schematic? I notice you list 30V after the rectifier but you have 15VAC and 12VAC being stuck in series after rectification which should be more like 38V.
The only beef I have with the 10uF cap on the FB loop node is that the response of the regulator to load changes is going to be on the order of 2ms although I don't think it would cause the problem we're experiencing.
As for the mute circuit, a pull-down on the bases of those transistors might be a good idea just in case. A far better mute would be implemented with a mercury wetted reed relay or JFETs (if the circuit impedance isn't too low).
Old 31st January 2010, 12:22 PM   #40
Geek's Avatar
I think we've drifted wayyy OT...
No relay for this particular model. Wetted relay would be more than the entire unit anyway. FFT didn't show issues with the bipolar.
FET, sure!
Maybe there's a bum cap or the reg's borked
Vin-Vo should be within the regs ability...
(I'm sure SY or Dave can split us off into our own MooseFET topic)
Cheers!
Long tailed pair schematic questions martyh Tubes / Valves 17 28th January 2009 11:27 PM
LTPZen, Zen with long tailed pair input stage Allen Newby Pass Labs 18 28th January 2007 04:19 PM
DC coupled long tailed pairs sajti Tubes / Valves 10 23rd February 2005 08:16 PM
CCS Conceptual Qs, Using Gary Pimm CCS as Example DrDeville Tubes / Valves 20 12th May 2004 03:41 PM
Long Tailed Pair Modification lubbie Solid State 31 11th May 2004 08:11 AM
Page generated in 0.11946 seconds (81.64% PHP - 18.36% MySQL) with 11 queries
