diyAudio Sponsor
Old 6th November 2010, 09:03 AM   #101
Yvesm is offline Yvesm  France
Yvesm's Avatar
OMG ! I missed this wonderfull thread and I've just read it back from the start with complete agreement with SY.
Now, what about using pentodes to obtain more gain (more drive) without any additional stage ?
The offender is that "shitty" screen current wich does not participate to the output voltage while it passes trhu the CCS and may unbalance the whole thing . . . at least until you read the Franck Blöhbaum 'Best Pentode" paper in Linear Audio.
Then you can use pentode LTP PI without adding some form of (un)balance adjustment . . . Problem solved
Yves.
Old 7th November 2010, 10:51 PM   #102
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Tektronix used pentode LTPs all the time. As long as you stay out of saturation, screen current is pretty much linear with plate current, so it balances out and nothing happens.
And when you hit saturation, cathode current essentially remains constant, which might actually be an advantage for clipping recovery -- the extra current being sunk from the screen. Even so, an LTP can easily be made so it "never" saturates.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 7th November 2010, 11:13 PM   #103
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Here you go, again:
http://wavebourn.com/forum/download.php?id=460&f=7
Concertina + LTP driving GU-50 output with parallel feedback:
http://wavebourn.com/forum/download.php?id=462&f=7
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Long tailed pair schematic questions martyh Tubes / Valves 17 28th January 2009 10:27 PM
LTPZen, Zen with long tailed pair input stage Allen Newby Pass Labs 18 28th January 2007 03:19 PM
DC coupled long tailed pairs sajti Tubes / Valves 10 23rd February 2005 07:16 PM
CCS Conceptual Qs, Using Gary Pimm CCS as Example DrDeville Tubes / Valves 20 12th May 2004 02:41 PM
Long Tailed Pair Modification lubbie Solid State 31 11th May 2004 07:11 AM
Page generated in 0.07374 seconds (71.92% PHP - 28.08% MySQL) with 11 queries
