diyAudio Sponsor
Old 30th January 2010, 06:39 PM   #1
Default Hello all, I´m new from Spain, sorry for my english, and problems with my music angel
In first time thank you, I was time ago reading your comments (very nice), but for problems with my english (is very poor) never was the pass of register.
Finally I´m registered because I have one Music Angel with EL34B model XD500-MKIII, I´me very, two week ago I replaced all chinese valves for a newTAD valves, the sound is improving, but I believe that is needed adjust bias.
Please can you help me I need schematics, ot tunnings for this.
P.D:
It´s my first valve amplifier, I´m happy, but, I don´t know, before I had a stereo yamha. My speakers are a B&W684
Thanks and I wait your responses.
Great forum.
Old 30th January 2010, 07:19 PM   #2
Svein_B is offline Svein_B  Norway
Here is the published circuit diagram. It may not fit exactly with your amp, since there has been some changes to components over time.
For bias adjustment, first measure the cathode resistors for the output tubes and note the value.
Let us assume they are 5 ohm (it may be two 10 ohm in parallel, one on each side of the circuit board). They are located on the circuit board at the back.
If you want to set the bias for an idle current of 40mA, there should be 0.2V across the cathode resistors.
The bias is adjusted with the blue trim-pots on the power-supply board.
There is one for each tube. After you have identified which one correspond to each tube you may want to mark them with a permanent marker.
NB: There is 400V inside so be careful!
Use clips on your test-leads so you do not need to hold them.
Use one hand for adjustment. The other hand on your back!
Svein.
Old 30th January 2010, 08:08 PM   #3
Svein.
Thank you for your very quick information, I´ll try to investigate whit this schematichs.
Thanks again.
Music Angel Amplifiers OXAUDIO Tubes / Valves 53 3rd February 2011 12:13 PM
KT-88 Music Angel problems with sound level wallagh Tubes / Valves 18 24th July 2009 09:39 PM
Music angel amps arvin Tubes / Valves 19 3rd March 2008 10:02 PM
Music Angel franckM Tubes / Valves 11 10th June 2007 11:24 PM
Music Angel EL34 SimonPearse Tubes / Valves 0 27th February 2006 08:27 PM
Page generated in 0.07641 seconds (76.61% PHP - 23.39% MySQL) with 11 queries
