use 120V x 2 for Aikido octal transformer? use 120V x 2 for Aikido octal transformer? - diyAudio
Old 30th January 2010, 06:19 PM   #1
ultrachrome is offline ultrachrome  United States
Default use 120V x 2 for Aikido octal transformer?
Just received my Aikido all-in-one octal kit and am getting ready to assemble.
I bought the kit with no idea about what transformer I'd need but it looks like my existing 120V x 2 toroid I have powering my grounded grid would work with the secondaries in series.
I have a hazy recollection of reading somewhere on diyaudio that the secondaries had to be connected in a certain way otherwise the transformer would heat up or something bad would happen.
I did not mark the secondaries so that I know which end of the wire is the first winding layer and which is the last and it's all wrapped up in mylar tape.
Is this important to know? Is there a way to determine this without unwrapping the outer insulation?
Old 30th January 2010, 06:35 PM   #2
Eli Duttman is offline Eli Duttman  United States
Energize the primary with low voltage AC. Phase the secondary windings up using a multimeter. The correct series arrangement of the secondaries will yield "2X" the excitation voltage. The incorrect arrangement will yield "zero" Volts.
Eli D.
Old 30th January 2010, 07:13 PM   #3
I get no voltage if I have it wrong? Thanks, that's simple.
Perhaps the comment I saw was in regards to using the secondaries in parallel?
Old 31st January 2010, 07:05 PM   #4
Kashmire is offline Kashmire  United States
Yea, if the secondaries are in parallel wrongly, it'll be a short-circuit.
use 120V x 2 for Aikido octal transformer?Hide this!Advertise here!
Using 230v Transformer with 120v Mains Phostenix Power Supplies 3 24th September 2009 08:46 PM
FS Aikido Octal linestage $75 nvrgdenuf Swap Meet 2 29th December 2008 08:35 PM
Calculating PS current for octal Aikido jrebman Tubes / Valves 4 25th March 2008 08:47 PM
I need a 120v ct transformer... Where to look? ThSpeakerDude88 Tubes / Valves 15 24th March 2007 02:19 AM
Octal Aikido? What tubes? jayme Tubes / Valves 8 31st December 2006 03:03 AM
Copyright ©1999-2017 diyAudio
