| diyAudio Sponsor | ||
I've got:
4 x DN2540 6 x 2N6520 8 x 2N3906 4 x LM317 8 x 2N3904 4 x IRFU310 Seen various designs and discussions involving these and not sure where to begin. Simple cascade involving 2 x DN2540's? So many opinions out there. Needing a CCS for a plate load on a 6N1P linestage. Currently using a SV83 as a CCS on the plate but would like to try a solid state CCS. Using led bias on the cathode. Suggestions would be appreciated. Thks Last edited by Brit01; 30th January 2010 at 04:53 PM. |
#2 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Have you got a schematic handy for this simple cascode design?
Thks SY. |
#4 |
#5 |
Thks SY.
Just spent the last hour trying to find that through all the threads. |
#6 |
SY
Am I going to need some small heatsinks for the DN2540's? Maybe going to pull 20mA with the 6N1P. |
#7 |
You may need a heat sink on the top FET, since it has most of the voltage across it. But maybe not- it depends on what you're trying to get your circuit to do- if it's a low level circuit with minimal swing requirements (a few volts), then you can set the B+ to be 30V or so higher than the predicted plate voltage. That way, dissipation at 20mA will be half a watt or less. If you're trying to swing lots of volts, then yeah, you'll have to make the B+ higher and heat sink the top one.
#8 |
Not sure which is the gate,source or drain on this diagram.
Please can someone advise? |
#10 |
Thxs SY.
Also another doubt: What wattage resistors are used here? (eg with 220 B+). Are they just setting the idle current? |
| CCs plate load for mu follower 6sn7 | duderduderini | Tubes / Valves | 4 | 8th November 2007 12:40 PM |
| plate load ccs ala gary p question | lt_texan | Tubes / Valves | 1 | 31st May 2007 04:32 PM |
| CCS Plate Load | Jack Thomas | Tubes / Valves | 4 | 21st May 2007 10:39 PM |
| Aleph-type CCS as plate load? | Fuling | Tubes / Valves | 18 | 22nd October 2004 02:46 AM |
| 6n1p pre with active load | Paracelsus | Tubes / Valves | 7 | 24th April 2004 01:03 AM |
| Page generated in 0.09664 seconds (79.70% PHP - 20.30% MySQL) with 11 queries |
