diyAudio Sponsor
Old 30th January 2010, 03:57 PM   #1
john65b is offline john65b  United States
john65b's Avatar
Default Um, Can I do this?
Hey all you smart tube guys,
I have been getting real interested in Balance Connections to amps lately. I have a Pass Aleph 5, Krell Clone, that have balanced inputs, and eventually building a Aleph JX...
Anyway, I have been shorting the neg input to ground for single ended connections, but have been thinking of this idea to build a tube pre Concertina style to balanced XLR connections - see attachment.
Is there any reason this won't work? No values are set yet, just proof on concept only. Note - I do not have a balanced source.
Thinking a 6SN7, 6922 or 6N1P Input tube...
If a horribly dumb idea, go easy on me, as I am very thenthitive.
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V
Old 30th January 2010, 04:12 PM   #2
Off the top of my head:
Sure it will work and as long as both outputs are equally loaded the concertina has approx 1/gm output impedance so it should behave... if equally loaded, which probably would be where I would have my doubts-cable impedance, input impedance etc need to be perfectly balanceed otherwise both signal balance and output impedance is compromised.
/Olof
I'm not allowed to do magic, union rules...
Old 30th January 2010, 08:04 PM   #3
Shoog's Avatar
Since you have two triodes why not just a LTP. You get gain with that configuration.
Shoog
Old 31st January 2010, 01:36 PM   #4
john65b's Avatar
OK, so I haven't heard that it cannot, or should not, be done.
LTP version attached. Feel free to advise on additional components. Afterwards we can look at tubes and component values. I am leaning toward a 7N7 (loctal 6SN7)
Again, I have read that Balanced arrangement is a waste unless the entire chain is balanced (source/Pre/Amp).
Am I spinning my wheels since my source is single ended??
Old 31st January 2010, 01:49 PM   #5
bigwill is offline bigwill  United Kingdom
Might need a topology with a lower output impedance to drive a cable + whatever is on the other end of that XLR cable, although with a short cable length and light input impedance it might work OK. If the load is heavy, you can cheat and feel good about it by buffering the outputs of the LTP using some MOSFET source followers
Old 31st January 2010, 01:56 PM   #6
john65b's Avatar
XLR Cables will be made short (a foot), and should be feeding a few amps with input impedance of between 47k and 100k
Maybe an ICEpower ASP1000 (20k-ish?)
Am I correct in thinking the Concertina type would offer lower output impedance, but lower gain, while the LTP would offer higher gain and higher output impedance?
Old 31st January 2010, 02:20 PM   #7
You are correct, although driving a 47k load from the anodes of a 6SN7 in an LTP is really pushing it - a typical anode resistor for the 6SN7 is already somewhere in this order of magnitude, and if you go by the rule that the actual load resistance should be 10x that, then you will be way off!
The Concertina will probably drive the load just fine, but then each phase has a different output impedance (Very likely someone will correct me on this)
How about going the whole hog and using two 6SN7s, one as an LTP and another as two cathode followers (one for each phase) to provide a good strong drive?
Old 31st January 2010, 02:33 PM   #8
For clarity here is a diagram (NOTE: Grid stoppers omitted)
You might want to float the heater supply on the cathode followers too, since the cathodes will be sitting at quite a high voltage, and a big heater to cathode differential is a Bad Thing
Old 31st January 2010, 02:44 PM   #9
The follower 6SN7s could be replaced with suitable MOSFETs too, if you want to save on tubes, which is understandable.
Old 31st January 2010, 02:47 PM   #10
leadbelly's Avatar
Shoog
? You'll get more gain going common cathode + concertina than taking those same 2 triodes and making an LTP.
Aerodynamics are for people who can't build engines. Enzo Ferrari
convert cm/dyne to um/mN pfcs49 Analogue Source 3 10th May 2009 07:59 AM
Um...silly question about integrating a HT sub GhettoSQ Subwoofers 9 3rd June 2007 01:50 PM
Um, I think this is bad. Stocker Parts 1 3rd June 2005 01:18 AM
My first, um, thing soneil Chip Amps 3 15th January 2004 04:37 AM
Um, just after a link really,... :-) Mos Fetish Multi-Way 3 16th June 2003 08:15 PM
Page generated in 0.10560 seconds (79.29% PHP - 20.71% MySQL) with 11 queries
