diyAudio Sponsor
Old 30th January 2010, 10:42 AM   #1
eeyore is offline eeyore  Australia
Default How to Spec Headphone output transformers
Can I ask a dumb question, is specifying an output transformer for a headphone really just the same as for a speaker, instead of having 8R or whatever as the secondary, it would be 600R or whatever, to match your headphone's impedance? For argument's sake, say I wanted to do a 45 Headphone amp, would I just use a 5k:600R for my Senn HD650?
Is it also true that the output stage should be designed more for power gain, rather than voltage gain?
DF
http://diy-audio-blog.blogspot.com
Old 30th January 2010, 03:41 PM   #2
Tom Bavis's Avatar
You REALLY don't have to worry about maximum power transfer when driving headphones, as they can deliver as much as 100 dB SPL with one milliwatt... use a 600 Ohm transformer and you'll be able to drive a WATT into them... they won't take it, and your ears certainly can't... and it will be tough to get the signal-to-noise low enough
If you're using 45s anyway, why not use a transformer with 8 ohm output and attenuate the output for the headphones? Most headphones aren't sensitive to source impedance and will sound just as good with a series resistor.
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Aikidos Headphone with Output Transformers? wonsup Headphone Systems 4 15th April 2008 05:34 PM
output transformer spec questions dsavitsk Tubes / Valves 8 25th January 2006 10:16 PM
Regulator Output Noise Voltage Spec TerryC Parts 2 23rd January 2006 04:46 AM
Page generated in 0.07380 seconds (70.84% PHP - 29.16% MySQL) with 10 queries
