| diyAudio Sponsor | ||
Custom Title
Please critique my schematic for a 12ay7 grounded cathode linestage using this trafo: http://jensentransformers.com/datashts/10kbd.pdf
I'd appreciate any feedback people may have. The trafo seems well-suited due to its high input impedance but modest ratio, so I keep a tiny amount of gain. Being an input transformer by nature, it wouldn't like DC so it's cap-coupled.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! Last edited by badman; 29th January 2010 at 08:43 PM. |
#2 |
I built a line stage using the 12AY7 tube, but with a cathode follower rather than transformer coupled. I found that 280V B+, with 100K plate rsistor and 1.8K for the cathode resistor (with 470 mfd cathode bypass) worked very well for the gain stage. Given the palte resisitance of the 12AY7, you probably want more B+ and more plate resitance for lowest distortion and greater swing.
Your drawing has an inadvertent error--the output is shown coming off the grid rather than the plate. |
#3 | |
Custom Title
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#4 |
Dude,
Look at the 12AY7 data sheet. RP is 25 KOhms. At least 3X the plate resistance, as the net load impedance, is necessary for low distortion. Your schematic shows a net load less than RP. ![]() Replace that 25 KOhm part with a 10M45S CCS, if you don't want to increase the B+ rail voltage.
Eli D. |
#5 | |
Custom Title
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! Last edited by badman; 30th January 2010 at 01:50 AM. |
#6 |
Remember, that impedances in parallel follow a reciprocal law, to yield the net. As far as AC is concerned, the 25 KOhm resistor and the trafo are in parallel, hence the catch word parafeed. The net must be less than the smallest item in the parallel set. There's good reason why the parafeed circuits you see show either a huge inductance or a CCS as the connection to the PSU.
Eli D. |
#7 |
Custom Title
My mistake. NET load. I was ignoring the plate resistor. You guys can see why I'm needing the help, my tube chops aren't too impressive.
#8 |
Yup, listen to Eli
I'm curious though, what is your signal source and what kind of peak swing can it deliver ? Have you considered turning things around, i.e. your transformer at the input, reversed (for voltage gain), and tube wired as cathode follower ? |
#9 | |
is there a chance that you post a schematic of your application ??? i have so many original motorola 12AY7 and i constructed afew things with them but i was never very happy with them kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#10 |
Custom Title
Hi Guys, Muffley:
280V and 100k do seem like more optimal operational points, though I'll probably juice up the cathode resistor a little higher, maybe 2.5k. Annoyingly, I'll have to change from a 6x4 fullwave to a solid state bridge to get the voltage needed. C'est La Vie. After this, I'll still have a lower load on the tube, 2x Rp, but that's a heckuva improvement.
| 12AY7 preamp schematic | sakis | Tubes / Valves | 6 | 13th January 2009 08:39 AM |
| RJM with 12AY7 | mashaffer | Tubes / Valves | 27 | 17th September 2008 12:42 AM |
| Please critique this 2A3 SE schematic! | SHiFTY | Tubes / Valves | 21 | 14th May 2008 10:51 AM |
| 12AY7 circuit? | sakis | Tubes / Valves | 29 | 22nd March 2008 01:00 PM |
| DHT Ultrapath Linestage schematic help | dsavitsk | Tubes / Valves | 6 | 15th January 2006 04:28 AM |
| Page generated in 0.11076 seconds (79.51% PHP - 20.49% MySQL) with 11 queries |
