| diyAudio Sponsor | ||
#31 |
Re-did the GU50 triode curves, 2nd set is an enlargement of the bottom quarter of the 1st. And tried g2 drive, and it worked OK for the limited step voltage available.
Plot1: triode mode: 20 mA/div vert., 50 V/div horiz., 5.5 V steps on g1 Plot2: triode mode: 10 mA/div vert., 50 V/div horiz., 5.5 V steps on g1 Plot3: g2 drive mode: 10 mA/div vert., 50 V/div horiz., 5.5 V steps on g2, g1 at +4 V, g3 at +2 V
Ohms Law V = I R Last edited by smoking-amp; 3rd February 2010 at 01:54 AM. |
#32 |
Tried to start on the 6F12P, but running into hum problems in the pentode curves now. (notice squeezed grouping by twos on left side) Triode mode came out not too bad surprisingly. I'll try again tomorrow when the tracer has cooled off. If I can't get rid of the hum problems, then I'll have to check the power supplies.
Plot1: pentode: 2 mA/div vert., 50 V/div horiz., 0.27 V steps on g1, 100 V on g2 Plot2: triode config. 1 mA/div vert., 50 V/div horiz., .55 V steps on g1
Ohms Law V = I R Last edited by smoking-amp; 3rd February 2010 at 02:38 AM. |
#33 |
Do you have any 7KY6 or similar frame grid pentodes? I did one once,
http://webpages.charter.net/dawill/t.../Data_7KY6.gif This graph was made by compositing photographs, so it's not too accurate. Fairly linear, and you can't beat the gain or the price. Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#34 |
Right above: 6F12P
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#35 |
Still having problems with power supply ripple, seems to be more obvious on smaller scale factor plots. I think I will just put some binding posts on the back of the tracer for an external reg. supply. But in the mean time I will try to finish up the tube plots as best possible for now.
"Do you have any 7KY6 or similar frame grid pentodes? " Sure do. Here are plots for a Magnovox (Japan) 7KY6, and an RCA 11HM7, which seem to be identical tubes except basing, & fil. I've got 12HL7 and 12HG7 too, which I'll add to the pile to do. Then a couple more tries on the 6F12P Plot1: 7KY6 pent. 10 mA/div vert., 50 V/div horiz., 100 V on g2, .25 V per step on g1 Plot2: 7KY6 triode mode 10 mA/div vert., 50 V/div horiz., 1.4 V steps on g1 Plot3: 11HM7 pent. ditto per 7KY6 Plot4: 11HM7 triode ditto per 7KY6 Hmmm, looks like the pentode curves are close but the triode curves are different. I'll have to recheck that one. May be just a DC bias adjust shift between plots. The tracer has an A:B compare switch so I will put them back in under same settings later to check. Plot5: 6F12P pent. 2 mA/div vert., 50 V/div horiz., .27 V steps on g1, 100V on g2 Plot6: 6F12P triode mode 2 mA/div vert., 50 V /div horiz. .55 V steps on g1
Ohms Law V = I R Last edited by smoking-amp; 3rd February 2010 at 05:27 PM. |
#36 |
Re-did the 11HM7 triode curve to match up the DC bias with the 7KY6, looks better matched now, but the 11HM7 curves are leaning over more at the HV end.
Only got one or 2 of each type, could just be that tube. Would have to test a few to see if that is consistent or not.
Ohms Law V = I R |
#37 |
Next up, 6U9/ECF201 and 6X9/ECF200
Plot1: 6U9 pent. 2 mA/div vert., 50V/div horiz., 100 V on g2, .55V steps g1, 0 V on g3 Plot2: 6U9 pent. 2 mA/div vert., 50 V/div horiz., 100 V on g2, .55V steps g1, +11V on g3 Plot3: 6U9 triode mode 2 mA/div vert., 50 V/div horiz., 2.75 V steps on g1 Plot4: 6X9 pent. 2 mA/div vert., 50 V/div horiz., 95 V on g2, .27 V steps g1, 0 V on g3 Plot5: 6X9 pent. 2 mA/div vert., 50 V/div horiz., 95 V on g2, .27 V steps g1, +11V on g3 Plot6: 6X9 triode mode 2 mA/div vert., 50 V/div horiz., .55 V steps on g1 6U9 looks like remote cutoff. 6X9 looks nice.
Ohms Law V = I R |
#38 |
Thank you Don!
#39 |
Here are the actual triodes in the 6U9 and 6X9.
Plot1: 6U9 real triode 2 mA/div vert., 50V/div horiz., 2.8 V steps on g1 Plot2: 6X9 real triode 2 mA/div vert., 50 V/div horiz., 1.4 V steps on g1
Ohms Law V = I R |
#40 |
Thank you!
Can you try 6P15P with negative G3?
| 300B SE cathode feedback to grid? | alan_982002 | Tubes / Valves | 3 | 29th March 2010 01:04 PM |
| Control grid Voltage / grid stoppers... | jon_010101 | Tubes / Valves | 2 | 4th May 2006 01:59 AM |
| CCS, feedback and grid leak questions. | bobhayes | Tubes / Valves | 35 | 9th October 2005 04:16 AM |
| 'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' | mikeks | Solid State | 62 | 20th July 2005 08:03 AM |
| Page generated in 0.11328 seconds (81.84% PHP - 18.16% MySQL) with 11 queries |
