Suppresor Grid used for Feedback?
Old 25th February 2010, 02:27 AM   #91
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
The combined g2,g1/Mu drive scheme seems like a practical solution for positive g1 and g2.
This only requires half the positive voltages of positive g1 only drive (and g2 need only go half as positve compared to fixed pos. g2 and neg. g1 drive). Grid currents scale like square law of pos. voltages I think. The plate voltage can then drop lower too (before going below g2 voltage).
Old 25th February 2010, 02:49 AM   #92
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
Totally. I think it makes a 2 stage screen drive amp a possibility. A couple of MOSFET followers and <=150Vpk drive stage (which is not that hard) traded off against a stable screen supply and a negative bias supply that you don't need... At the lower drive voltages vs. g2-only drive it would work with parallel (shunt) plate-grid feedback. Plate efficiency goes up a few % in class AB for some test cases of 50W PP sweep tube amps using 17W tubes. Quiescent current can also I think be reduced as the transfer function seems more linear.
Michael
Old 25th February 2010, 03:32 AM   #93
tubesteve is offline tubesteve  China
tubesteve's Avatar
Location: since 1998 in China as an electronic consulting design and testing engineer
Default 6p1
6P1 is same construction as 6AQ5
The amount of humans is increasing, but the amount of available intelligence remains a constant.
Old 25th February 2010, 04:33 AM   #94
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
FYI, tubes are usually built with nickel, an excellent ferromagnetic element (and half the content of such legendary alloys as permalloy). Ni's curie temperature is 358C, so most of the components inside an operating power tube will be demagnetized (above the curie temp.), though not necessarily a tube on the curve tracer.
When you apply a toroidial magnet, you're bringing a dipole field near, which is basically all fringing flux. This means the field is diverging above and below the magnet. Since electron paths are bent perpendicular to the field lines, you will get an axial spiraling, which will tend to move the beam of a beam tetrode away from the plate seam and towards the suppressor plates and grid supports. Since the field is divergent, electrons will also be bent up or down, which will increase screen current. One might speculate on the effect of secondary emission (which seems to be worsened, although only at high current, as in a pentode, not to the point of negative resistance at low current density, as in a beam tetrode), but I don't have a convincing explanation for that.
And note this doesn't even take into account the channeling of flux inside the magnetic components, which should act to reduce divergence (except at the open end, on top) and make a somewhat more uniform distribution of magnetism along the length, butbe left with localized spots of higher intensity (such as supports, corners, cold spots, etc.).
Hmm, now I wonder what a tube does when hot. That could be tested by building a standard magnetization fixture (i.e., a glorified solenoid around the tube, with calibrated currents applied), and testing after running at rated power for a few minutes (so the structure is hot, past the curie temperature in places). Then watch how it changes as it cools down.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 25th February 2010, 02:15 PM   #95
As TubeSteve says, 6P1P appears to be identical in specs to a 6AQ5, which has a g2/g1 Mu of 9.5. So I rigged up the 6P1P 4400 (hysteretic) with g2,g1/Mu drive using a 1K Ohm resistor from g2 to g1, and a 100 Ohm resistor from g1 to cathode. Drive on g2 at 5.3 V/step.
Plot1: g2,g1/Mu, 50 V/div horiz., 5 ma/div vert., 5.3 V steps
Plot2: g2 only, ditto, g1 at 0 V
Plot3: g2 only, but changed to 2 mA/div vert.
Seems to still have hysteresis in g2,g1/Mu mode. Still a bit in g2 drive only too. Plot 1 versus Plot2 verifies that each grid is doing half the control.
I also tried banging this tube hard on a vinyl floor mat to see if I could affect the g2/g1 alignment, but couldn't see any difference, and the hysteresis stayed the same too.
On the g2 current with positive g1 thing again, I've been thinking that maybe a tube with 180 degree g2/g1 alignment (g2 wires exactly in between the g1 wires) might be the ideal arrangement to avoid focusing current onto g2 wires. If I ever see some very badly aligned tube I'll test that.
edit: added the non hysteretic 3950 6P1P tube in g2,g1/Mu mode for comparison, same scale as Plot1. Curves look great in g2,g1/Mu, no rounding at all.
Old 25th February 2010, 04:23 PM   #96
"When you apply a toroidial magnet"
I tried a simple axially symmetric rectifier tube, 19Y3, in a magnetic field from a stack of strong toroid magnets here. They are stacked about 4 inches high and slipped over the tube for the axial case. Perpendicular case has the tube stuck to the end face. Scale for plots is 2 V/div horiz. and 10 mA/div vert.
Plot1: no field
Plot2: axial field case
Plot3: perpendicular case
I tried both directions of the magnetic field for the axial case, and they were the same as expected. Also tried both polarity fields for the perp. case, and the same result.
Looks like an axial field works well for increasing the plate resistance.
Should be interesting to try this on an axial sym. triode to see if it affects the Mu or not.
Edit: added earlier plots as plot 4 and 5 here of the 6P1P in normal g1 drive mode for comparison with the previous g2,g1/Mu and g2 plots shown above. Plot4 has 100 V on g2 and Plot5 has 200 V on g2.
Old 25th February 2010, 05:23 PM   #97
Here are some curves for a 6S4A triode with axial magnetic fields. This tube has a circular cathode, the grid is crimped around the cathode (nearly round) from further out posts and the plate is flat type.
Plot1: normal triode operation, 50 V/div horiz., 5 mA/div vert., 1.2 V steps g1
Plot2: axial field along tube, ditto, same grid bias as above: 0V grid for max curve
Plot3: axial field along tube, ditto, adjusted grid bias positive for max curve
Seems that the electrons can't get past the grid with positive grid in Plot3. Must be spiralling into the posts.
Appears that Mu and gm got decreased in Plot2
Old 5th March 2010, 10:47 AM   #98
tubesteve's Avatar
this discussion was very interesting, are there any new points / ideas about G3 voltage supply?
Old 5th March 2010, 03:24 PM   #99
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Hmmm... Is a current limiting rectifier already patented? Just put a rectifier tube inside of a choke ...
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 5th March 2010, 03:35 PM   #100
Wavebourn's Avatar
Still, mysterious why some tubes do the hysteresis thing and others don't.
Different tension of the 1'st grid, so temperature changes geometry differently?
Suppresor Grid used for Feedback?Hide this!Advertise here!
300B SE cathode feedback to grid? alan_982002 Tubes / Valves 3 29th March 2010 01:04 PM
Control grid Voltage / grid stoppers... jon_010101 Tubes / Valves 2 4th May 2006 01:59 AM
CCS, feedback and grid leak questions. bobhayes Tubes / Valves 35 9th October 2005 04:16 AM
'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' mikeks Solid State 62 20th July 2005 08:03 AM
