diyAudio Sponsor
Old 1st March 2010, 10:50 PM   #21
xmas111 is offline xmas111  United States
Kevin,
The 6SN7's sound terrific!
I ended up putting together a ( 12 volt ) bucking transformer to knock down the line voltage a little. My line voltage can run as high as 128 v and a low of 123 v which is way above the recommended 115 v.
Now with the line voltage running lower I'm curious if I can raise the KT88's bias a little bit higher than the recommended .55v to .65v? Well maybe that's getting a little greedy!
And your right about us being close to each other. I'm in Plymouth. And I might take you up on meeting some local tub-o-philes someday. Sounds like it would be a great education and experience.
John
Fun Stuff:AR XA Turntable Restoration
Yaqin MC-100b schematic diagram aristocrat Tubes / Valves 166 23rd June 2011 04:05 AM
Yaqin MC-100b channel imbalance al3700 Tubes / Valves 1 22nd October 2009 07:35 PM
yaqin mc-100b jaks Tubes / Valves 7 23rd February 2009 08:11 PM
Page generated in 0.16080 seconds (36.23% PHP - 63.77% MySQL) with 11 queries
