diyAudio Sponsor
Old 29th January 2010, 06:31 AM   #1
Default heater warmup and b+ delay
I've always been careful to warm the heaters before applying b+ because I'm a sensitive guy.
Lately I've been confronted with some notions implying that this is nonsense on indirectly heated tubes.
I've always thought that even indirectly heated tubes need the electron cloud around the cathode (space charge) to provide protection from ions and other bad stuff in the surrounding nether before applying high voltage to the plates.
No text in manuals/books exists (in my search) regarding indirect-heaters and high voltage. The heater cathode is always mentioned in a by-note in passages regarding other cathode types.
Please check this link out before replying:
http://www.freewebs.com/valvewizard1/standby.html
I would be much happy if I can eliminate the bothersome standby switch and all worries surrounding the issue.
Old 29th January 2010, 08:31 AM   #2
The issue is cathode stripping. Below 400 V., cathode stripping is (IMO) pretty much academic.
In an amp with "fixed" bias O/P tubes, an instant on, SS rectified, bias supply will prevent cathode stripping, as long as B+ rise is slightly delayed. A NTC inrush current limiting thermistor supplies the requisite delay, when SS or directly heated vacuum rectification is employed. Vacuum rectifiers with cathode sleeves automatically exhibit a slow B+ rise.
Eli D.
how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? jarthel Tubes / Valves 9 14th April 2012 05:36 PM
Regulated Heater on the 6SN7 Aikido Plate to Heater question john65b Tubes / Valves 6 24th November 2009 05:44 AM
Pitfalls to warmup delay in DC coupled multiple railed amps? leadbelly Tubes / Valves 3 20th March 2009 07:29 AM
Different Rectifier Warmup Times bloozestringer Tubes / Valves 13 9th November 2008 01:26 AM
Distortion after warmup dougpke Multi-Way 12 21st April 2004 03:48 PM
Page generated in 0.05914 seconds (70.50% PHP - 29.50% MySQL) with 10 queries
