diyAudio Sponsor
Old 29th January 2010, 05:38 AM   #1
revintage's Avatar
Default BAL to UNBAL DAC buffer
Kind of instrumentation amp. Any clues if the good simmed results are valid IRL?
Brgds
Lars
Old 29th January 2010, 06:11 AM   #2
revintage's Avatar
Oooops!
Wrong picture, should be this one:
Brgds
Lars
Old 29th January 2010, 06:24 AM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
why not?
but - maybe it's better as full SUSY - having NFB on both sides
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 29th January 2010, 06:30 AM   #4
revintage's Avatar
Hey Zen Mod,
Must find out what a "full Suzy" is.
Found an error, R10 should not be DC-connected to ground. Cap should be added in series.
Brgds
Lars
Old 29th January 2010, 06:37 AM   #5
Franz Gysi's Avatar
Supersymetry
BTW: I miss the grid resistors (grid to ground).
Franz
Old 29th January 2010, 07:20 AM   #6
revintage's Avatar
Originally Posted by Franz Gysi View Post
Supersymetry
Franz
Hey Franz,
Yep I know of Pass Suzy(even not in detail), just couldn´t figure out how Zen Mod wanted to apply it here.
About the gridresistors, none are needed as the DAC is DC-connected and bias the grids to +2,5V. With over 5V on the cathodes no negative supply should be needed for the CCS.
Brgds
Lars
Old 29th January 2010, 07:29 AM   #7
analog_sa's Avatar
Maybe not for the ones with an arrow inside a circle Who makes them?
Old 29th January 2010, 07:34 AM   #8
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Yes, it will work.
I used a similar circuit on my CD63 a couple of years ago.
( It's on the huge thread somewhere....)
I used E88CC at an anode voltage of 30v
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 29th January 2010, 07:42 AM   #9
revintage's Avatar
Will also work with a single BJT CCS. With over 5V DC and a signal of under 1V no problems will occur.
Finally found your amp and found it farfetched to call ours alike. But sure, you used two triodes and took the output signal from one of them. Maybe you changed the circuitry later in the thread as the one I found looked rather basic. Can you show it again?
Brgds
Lars
Old 29th January 2010, 08:12 AM   #10
poynton's Avatar
Yes, the diagram on the thread is basic, to say the least !!
The input was modified from T-L's published circuits and the triode stage was better developed, of course.
Sorry, I can't be more explicit at the moment ... most of my stuff and the final stage is in storage.
Andy
converting BAL to UNBAL using tubes and without transformers sunrise Tubes / Valves 101 24th November 2008 07:26 PM
PCM1804 bal/unbal adc meta Digital Source 14 7th February 2007 06:44 AM
Bal-Unbal-Bal Cable Wiring richie00boy Everything Else 3 3rd February 2005 11:08 AM
New TI chip unbal to bal markp Solid State 9 25th January 2005 08:16 PM
Bi-amp with Aleph P bal. and unbal. outputs Sony Pass Labs 3 21st December 2004 07:09 PM
Page generated in 0.09328 seconds (80.44% PHP - 19.56% MySQL) with 11 queries
