Counterpoint SA-7 - need a pic of the inside
Old 29th January 2010, 05:38 AM   #1
revjac is offline revjac  Canada
Default Counterpoint SA-7 - need a pic of the inside
Specifically the upper right segment of the board. Guy brought in one to have a cap replaced because he didn't want to do it but the cap had already been pulled and I don't know which way the replacement needs to back in. It's the 25V-1000uF.
Can't seem to find a pic on-line anywhere!
Any help is greatly appreciated.
jac - desperaudio @ large
Old 29th January 2010, 05:50 AM   #2
Pars is offline Pars  United States
Pars's Avatar
there are some pics in this thread (2 min in google). I would think neg goes to ground, but I know some of CP stuff is floating, so figuring that out might not be obvious
Smoking resistor on counterpoint SA7 preamp, any help? - Page 3 - AudioKarma.org Home Audio Stereo Discussion Forums
Old 29th January 2010, 03:23 PM   #3
Default the picture
here's a pic - the one I forgot to add last night
Old 29th January 2010, 03:28 PM   #4
Pars - thanks! That is exactly what I needed. (I saw that thread but didn't follow it far enough along to get to the pics.
Tacka du
Old 29th January 2010, 05:51 PM   #5
poynton is offline poynton  United Kingdom
poynton's Avatar
Just a note :-
The big problem with the SA-7 is that the phono stage is permanently in line even when switched to one of the other inputs.
This is due to the switch type.
I changed the selector switch to ON - ON - ON 2-pole 3-way
I got mine from RS but I am not sure if they still stock them.
It made a significant improvement to noise levels and "sound quality".
Fitting time was about 1 hour.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 29th January 2010, 08:14 PM   #6
Well - that, to me, sounds like a good idea. I'm going to get this one up and running first and if the owner wants to start some tweaking (and he's already talking that way) then I'll revisit this idea with him.
tanx!
Old 29th January 2010, 08:36 PM   #7
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Oh mine gott... Was it designed by professionals?
The Devil is not so terrible as his math model is!
Old 29th January 2010, 10:14 PM   #8
poynton's Avatar
Supposedly.......
There seemed to be some good (?) ideas but some things were left to be desired.
One good thing with Counterpoint ( or bad thing with their UK distributer ) ..
I did not have a service manual / diagram and contacted the UK distributer. ( A well-known company in Wimbledon )
They refused point-blank to supply it !
After contacting Counterpoint in the States, I received the required information by return Express airmail.
Andy
PS ... I bought my SA-7 for 50GBP at a large car boot sale in Surrey. It was being sold by a guy from the back of a Rolls Royce and was buried on his stall between some books and junk. I just about spotted it as I walked past. He let me audition it at his house. He was selling to upgrade to Krells.
Old 2nd June 2010, 01:58 PM   #9
stereoitis is offline stereoitis  Canada
I have one at home we seem to be in the same city if you would like to take a boo
Counterpoint SA-7 - need a pic of the insideHide this!Advertise here!
counterpoint Sa 5.1 max29 Tubes / Valves 304 6th November 2017 02:54 PM
counterpoint sa-100/sa-220 schematics? Williams Audio Solid State 15 12th June 2017 09:45 PM
counterpoint sa-100/sa-220 schematics? Williams Audio Analog Line Level 3 24th February 2006 06:46 PM
Counterpoint SA 7.1 ppridday Swap Meet 3 17th October 2004 08:07 PM
Copyright ©1999-2017 diyAudio
